General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Snap-on, MAC and others like them are VERY expensive.
I'm using Craftsman click type torque wrenches in 1/2" and 3/8" and they are certainly good enough for the home mechanic. Although you'll hear of the reason to spend $200-$300 on one, though.
I got about 5 a matco 1/2" drive a cheapy 1/2" drive hardly ever use and a craftsmen 1/2" and a 3/8" inch/lb and a Kobalt 1/2". Out of all them I like my kobalt the best plus it will torque when in reverse (counter clock wise) it is easy to read and spent right around $60 for it on sale it looks identicle to a snap-on .My 2 cents
I have two Craftsman wrenches. One 1/2" drive in Ft. lbs. and the other 3/8" in inch lbs. They have served me well and for the limited use they get I can't justify spending $200-$300. I have heard some guys say their Harbor Freight models work for them. I own some harbor freight tools (mostly air tools) and I don't think I'd want to trust their torque wrenches. Get what you can afford and based on the service duty you expect them to see.
Have SnapOn 1/2 "foot pound. Forty plus years old. Think I paid around $100 then and thought that was huge. But then I wretched for a living too, so one of those tools needed. Have an inch pound beam wrench I used on pinion bearings. Bought an inch pound clicker from local industrial supply house on sale and discount for around $50.
All this said......Sears or kobalt are excellent choices.
Reason: Auto correct
I use the Harbor Freight 1/4 inch for inch-pounds and 1/2 for foot pounds - these cover every value I've come across. I've had better (Craftsman) and worse ones (the old spring type) over the years but these have been surprisingly reliable and accurate as I would want short of "dead on b*llz accurate".
Get the click type as suggested. Make sure you unload the spring setting after each use when storing. I have 3, an inch pound screwdriver type, an inch pound 3/8" drive, and a foot pond 1/2" drive. I also have access to a foot pound 3/4" from work if I'm doing a compensator/rotor-stator.
I would avoid the dial/indicator arm type.
Yes if all you're doing is your own work and not often a Craftsman will do.
