Homemade shifter linkage
A 14" piece of 5/16" aluminum rod is the main piece (cut to length), with 5/16 x 24 female threaded heim joint ends, and lock nuts which are also 5/16 x24 thread, are all the parts needed to make the link rod. Also needed are two 1" long 5/16 x 24 chrome button head bolts, and an acorn nut and washer, which may already be on your bike on the front of the stock rod.
These parts can all be obtained online, or locally if you have the sources.
The eye-to-eye length I was going for was 14 3/4" center to center, so I cut about 3/4 " off the rod to start. This bike had a solid stock rod with the attachment ends that do not unscrew from the rod, and the diameter was too thick to simply cut off the ends and thread it. It is a 2006 Street Bob.
After initial cutting, I threaded both ends by holding the rod in the vise with aluminum softjaws, so that the vise didn't mar the rod badly while holding against the twisting force of the die handle. I cut 5/16 x 24 threads on each end, making sure not to cut too far so that the threads would not show once finished.
Assembled the pieces, checked the length, added a couple more threads, tightened it up, then went to it with the polishing wheel and rouge before mounting it up with blue locktite.
I think it turned out very well, and it works with a much more solid action than the stock piece with the double-flexy construction. I've probably got about $15 dollars in parts into it, and about an hour of relaxing work.
Pic link (for some reason the forum picture upload function is not working for me today)...
http://smg.photobucket.com/user/Shan...xvwbk.jpg.html
All the best,
Shane
http://www.ebay.com/itm/Chrome-Gear-...1XOsfg&vxp=mtr
I thought about getting one like this as well, but I like to make things, especially when I get to use tools (this time, it was the die) that came from my wife's grandpa, who died before I met my wife.
Shane
Pic?
Shane
