more on clutch recall
Old Sep 15, 2016 | 07:01 AM
Wisenheimer16's Avatar
Wisenheimer16
Default more on clutch recall
Thanks to Back-n-Black for providing the service bulletin.. It says if the bike passes inspection (no air bubbles present) then there is no need for any further action. I am thinking to check for air bubbles myself and avoid the long trip to dealer if possible. Has anybody done the inspection themselves and what were your findings?
File Type: pdf
Old Sep 15, 2016 | 03:51 PM
Wisenheimer16
Ok I am sorry to keep obsessing over this, but the service bulletin is clear. No bubbles=button her up and you are done. I removed the clutch master cylinder cover and gently pumped clutch lever after tapping the lever 4 times as service bulletin says. I did this for several cycles. No bubbles. I'm calling it good. Save yourself a trip to the stealer. (This took less than 5 minutes to accomplish)
tpcowfish
2014-2024 Touring Models
15
Jun 15, 2015 09:24 AM
wastedranger
Apr 20, 2015 07:51 PM
Govno
Apr 20, 2013 12:25 PM
allenp99
Apr 25, 2008 03:56 PM
sparky_mo
Mar 25, 2007 10:07 AM
