Higher Elivation
Old Oct 22, 2016 | 09:29 AM
guitar413's Avatar
guitar413
Stage III
Default Higher Elivation
Last month I rode threw the Rocky Mountains. As expected my power lessened the higher I went
I have a 2005 RoadKing Classic EFI, I have the S&S 510 cam Kit, Power Commander III and Python slip ons, Stock air cleaner.
What would be a relatively inexpensive way to get a little more while at higher elevations?
Other then that the bike runs really good and I don't want to change that.
Old Oct 22, 2016 | 09:32 AM
dfwhockey17's Avatar
dfwhockey17
Without O2 sensors, your bike cannot adjust to the elevation like it could with them. Shy of having the bike tuned with your PCIII at elevation, you cannot do much...
Old Oct 22, 2016 | 09:37 AM
guitar413's Avatar
guitar413
Stage III
Thanks, also thinking of getting true dual exhaust. Would that help at all.
When you say "Without O2 sensors", Are you saying that with the Power Commander III it cant adjust or take proper map readings?
Old Oct 22, 2016 | 09:54 AM
QC's Avatar
QC
That is correct. Even with them, the system will only adjust so much.
A freer flowing exhaust system will help, but not true duals. A good 2-1 system is better for making power.
Old Oct 22, 2016 | 09:59 AM
Max Headflow's Avatar
Max Headflow
Without going to a super charger (can compensate for the loss of air density) the easiest thing to do is increase displacement and compression ratio.. The base EFI system has the ability to compensate for changes in air density when tuned right. Not sure how the PC handles things as it simple rides on top of the stock Ecu.. Motor will probably get a little rich tho..
Old Oct 22, 2016 | 10:04 AM
QC's Avatar
QC
Amazingly enough, I rode for 5 days around the west central area and was getting 58 MPG vs. my usual 42 MPG here in town. All other riders that were with me experienced the same puzzling phenomena.
Old Oct 22, 2016 | 10:38 AM
Max Headflow
At altitude correct?? Whats your point?
Old Oct 22, 2016 | 10:50 AM
QC's Avatar
QC
Yes at altitude. The point being conventional wisdom would dictate that with less air density the machines would run rich, therefore less MPG. However, we all experienced significant jumps in MPG. I'm not smart enough to figure it out.
Old Oct 22, 2016 | 11:31 AM
Max Headflow
Depends on the number of factors, You can still run rich lambda and get better mileage at altitude.. Also how rich you run depends on the fuel delivery system.. Some do a better job of compensating then others.
Old Oct 22, 2016 | 03:59 PM
qtrracer's Avatar
qtrracer
MAP sensor(manifold absolute pressure) gives the ecm the changes in pressure to compensate for elevation changes.
