Backfire through air cleaner
Old Nov 11, 2016 | 10:31 PM
Matthew Bingham's Avatar
Matthew Bingham
Stage III
Default Backfire through air cleaner
I have a 2015 Road Glide Special. I recently had the Cobra Speedster duals, Powervision tuner, and the Roland Sands Clarity air cleaner installed.
I road up to Pennsylvania Monday (from Va) and noticed I would get backfires through the air cleaner at times while accelerating. I also noticed that while holding the throttle steady at a slow but constant acceleration it would slowly accelerate and then I would literally be thrown back in my seat with a ton of acceleration (I get the same result with the cruise control on).
Any thoughts? Regardless I'm taking it back to the shop that does my work Tuesday but would like advice in narrowing it down.
Old Nov 11, 2016 | 11:53 PM
Next In Line's Avatar
Next In Line
You have the wrong map installed.
Old Nov 12, 2016 | 12:52 AM
Matthew Bingham
Stage III
Should I just tell the shop to Dyno it?
Old Nov 13, 2016 | 06:57 AM
DonnieM's Avatar
DonnieM
What NIL said. Getting the correct map should correct the problem unless you want to throw more money at it by dyno too
Old Nov 13, 2016 | 09:03 AM
Max Headflow's Avatar
Max Headflow
Get the bike tuned..
Old Nov 16, 2016 | 11:59 AM
Next In Line
The timing is incorrect.
Unless the dyno-tuner corrects the timing, you will never get rid of the backfire.
martin10
Dec 17, 2025 12:48 PM
SportTeeRider
Jul 9, 2016 02:52 PM
FLSTF
Engine Mechanical Topics
Sep 4, 2015 05:33 PM
CharruaHD
Nov 19, 2012 07:39 PM
flhxkiller
Feb 20, 2010 10:52 AM
