No power
Old Dec 4, 2016 | 04:24 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by nevil
Next time you're working with wiring you might want to disconnect the battery first.
His best bet is to not work with wiring and bring the bike to a professional...
Old Dec 17, 2016 | 04:00 AM
realjewel69@gmail.com's Avatar
2nd Gear
Cool No power
Originally Posted by roussfam
You can change a coil, replace an ignition switch, remove your fuel tank (both of them?), but you can't check a fuse?
Something doesn't add up
I don't have a fuse box,I have a Dyna 2000 digital ignition systems!
Old Dec 17, 2016 | 06:18 AM
roussfam's Avatar
roussfam
something tells me you better bring it to a mechanic...
Old Dec 17, 2016 | 07:56 AM
bad tappets's Avatar
bad tappets
Good judgement comes from experience, experience comes from bad judgement.
Do yourself a favor, spend $60 on a factory service manual, it will save you a lot money in the long run. Elect diagnostic and parts manual are really helpful as well.
Check fuses!
Old Dec 17, 2016 | 10:12 AM
Max Headflow's Avatar
Max Headflow
What year bike / model do you have? You can't blow a coil by sparking wires.. You might it you let 12v sit across it for a long period of time.. Split tanks implies an EVO or earlier..
Do you have lights?
Old Dec 17, 2016 | 12:59 PM
hardheaded's Avatar
hardheaded
put down the tools and step away ! get your owners manual out and see where your fuses are located and which one is the main. remove and replace. if you can change a light blub you should be able to handle this.
Old Dec 17, 2016 | 03:06 PM
Dan89FLSTC's Avatar
Dan89FLSTC
I think you need to check the cam rivets.
Old Dec 18, 2016 | 10:58 AM
2deuceguy's Avatar
2deuceguy
VanHalen
Sep 6, 2018 02:21 AM
bluberryjenkins
Electrical/Lighting/Alarm
Jan 21, 2015 06:24 PM
bassdad
Sep 9, 2012 07:38 PM
boatsswain
Jul 13, 2011 08:06 PM
capt_caveman
Mar 27, 2011 09:56 PM
