Throttle Body Intake Valve Noise
Old Mar 2, 2017 | 06:21 PM
petejoe43's Avatar
petejoe43
Default Throttle Body Intake Valve Noise
Own a 12 Ultra 103" with a recent Stage 2 install including 2.5" baffles, 2-1-2 Rush headers minus Cat, Andrews 57H cams, and an S&S stealth intake. The bike performs better than expected, and this noise is minor to the point that you have to get your head down to Rocker Box level to hear it. There is a definite "clack/clack/clack" coming from the butterfly valve behind the new air cleaner. I removed the cover/filter and lightly tapped on the valve with engine off. Sure enough, that is in fact the noise. This is one of the most quiet 103"'s I've ever heard overall, but the clack clack is on my nerves.
Has anyone with a Stage 2 experienced this? Like I said, it's not noticeable unless you get down close. However, the aluminum intake plate tapping against the aluminum throttle body housing is most definitely the problem. I say this because I'm sure many have experienced this who must have thought the noise was coming from pushrods/rockers. It's not, it's the butterfly valve on the throttle body. I know what you guys are thinking......dude you're whining, just live with it. And I'm prepared to live with it, I'm posting this primarily to see who's found a fix for this or attempted one? The first thing that comes to mind is a rubber/plastic gasket to wrap around the valve....that would do the trick. But as far as I know, no such fix exists. I'm not going to dwell on it.......I'm sure someone here has taken a stab at this.....surely
Old Mar 2, 2017 | 07:38 PM
Rumblin's Avatar
Rumblin
I am not sure I had the noise you are describing. I had a larger intake\throttle body installed. If I pushed the throttle hard closed, it would go away. What I did to fix it was I use the set screw on the TB and crack it open until the I could push the throttle closed and it wouldn't change the sound. That did it. I surmise that the air crack was such that the butterfly was fluttering.
Old Mar 2, 2017 | 07:44 PM
ROCKOUT Rocker Products
Sponsor
Typically it's not the butterfly valve itself, but "intake reversion".... sounds like someone in there tapping on a little wooden drum. The open AC lets the sound out that the stocker was covering up. The 57H cam is known for making the noise worse. (I run one too)
For a short time I ran a Ness Big Sucker open back AC, but couldn't take the noise & went back to stock.
It's one case where they really all do that.
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Mar 2, 2017 | 08:49 PM
Uncle Fuzzy's Avatar
Uncle Fuzzy
Just installed stage 2 Andrews 48 on an 08 SG and having the same issue. I played around a bit w settings on FP3 and it got worse when hot idle was lowered to 900 rpm. Reset to 1000(default) and it helped but it's still there.
Really annoying.
Subscribed.
Old Mar 2, 2017 | 09:00 PM
petejoe43's Avatar
petejoe43
I hear what y'all are putting down, but I still believe there should be a fix for this. Admittedly, mine is only noticeable if my ears are a foot or so away, but it's still THERE......my OCD is kicking in on this. I have a 30 year HD master tech a couple of miles away from me. I'm gonna swing by the shop on my way home tomorrow and pick his brain. Will follow up.......
Old Mar 2, 2017 | 09:13 PM
QC's Avatar
QC
I am running the 37s and I can hear the valve events. I like it.
Old Mar 3, 2017 | 08:59 PM
dfwhockey17's Avatar
dfwhockey17
This is the answer...
Old Jul 30, 2023 | 09:50 PM
QC's Avatar
QC
Is your car built by Harley-Davidson?
Old Jul 31, 2023 | 10:47 AM
kloccwork419's Avatar
kloccwork419
Originally Posted by nobes
So lately, I found out that whenever i start my car, there will be a click sound coming off from the butterfly valve or some people call it the throttle valve. It only clicks for the first 15 or so seconds, but i don't know what does that mean... I did touch the tps recently but does that mean it's tps related?
The car is completely fine i suppose since it drives nice and idle fine.
Someone please help.
Try a Ford or Chevy forum.
Old Jul 31, 2023 | 11:24 AM
roussfam's Avatar
roussfam
Great first post
