Strategies to alleviate buffeting?
Old Mar 9, 2017 | 09:08 AM
gchristopher9's Avatar
gchristopher9
Default Strategies to alleviate buffeting?
I'm wondering if anyone can make some suggestions on what I might try to eliminate the buffeting I'm experiencing with my full face helmet. I'm currently running a 16" shield on my deluxe with lower wind deflector fangs installed. I've got a nice clean pocket of air when riding with my half helmet, but when wearing my full face, I get just enough buffeting to be annoying at highway speeds. I was hoping to run this setup for longer road trips, but it is not something I would even considering with the buffeting I'm experiencing. What else have you tried that worked for you?
Old Mar 9, 2017 | 11:05 AM
Yamaharley's Avatar
Yamaharley
Loose the fairing. That's probably what's causing it. A non fairing bike and a full face shouldn't have buffeting really at all.
Old Mar 9, 2017 | 11:43 AM
bad tappets's Avatar
bad tappets
Some full face helmets are designed for sport bikes. They work really well when sitting forward, but catch air underneath when sitting upright on a cruiser. Also may be air coming up from below due to windshield.
Old Mar 9, 2017 | 02:06 PM
gchristopher9
Well removing the shield (not a fairing) seems like an obvious solution. Not sure buffeting is even an issue when you're not running a windshield. Unfortunately ditching the shield isn't the solution I'm looking for. Running the windshield eliminates the massive wind pressure you have to fight when driving without one on the highway at speed. If were to do a multi day trip I would absolutely want the shield on there.
The thought of the wind coming up from underneath had occurred to me as well. I have tried using my arm to block the wind coming up from underneath but it has no effect. I think the fangs are already doing an excellent job of blocking this wind. It is proving to be pretty difficult to pinpoint exactly where the buffeting wind is coming from. I'm wearing an Arai Signet Q helmet, which if I'm not mistaken is actually marketed as being designed for an upright riding position.
Old Mar 9, 2017 | 07:30 PM
TriSum's Avatar
TriSum
Not trying to be a smart *** here, but have you tried different riding positions to see if you can feel where the air is coming from? IE: tilting your helmet fore and aft or slouching down more or sitting more upright? Can you tilt your windshield any? See if it changes.
Just throwing some things out there if you haven't tried. Good luck!
David
Old Mar 10, 2017 | 09:42 AM
son of the hounds's Avatar
son of the hounds
You do not show a photo of your setup, so all we can do is guess. I have a guess, but it is useless to you as it is just one of a dozen potential cures.
Old Mar 11, 2017 | 10:43 AM
gchristopher9
David
Great ideas. I have not done much to try to reposition my body to see if that helps. I have tried the "arm across the chest" trick that people often try before buying lowers, and that does not provide any relief. My windshield isn't designed to be adjustable but I could probably put some spacers in there to adjust the angle a little bit. Perhaps standing it upright a little more would help.
Old Mar 11, 2017 | 10:44 AM
gchristopher9
To be honest it doesn't seem necessary to me. It looks like every other softail out there running a windshield and fangs. I would be curious to hear your suggestions though. If you can think of a dozen different ways to cure my issue then I'm all ears.
Old Mar 11, 2017 | 11:16 AM
ROCKOUT Rocker Products
Sponsor
Along with the fangs I put the Kury under the forks air baffle thingy on my Limited... made a noticeable difference. Not earth shattering, but there. Almost hidden when installed too.
Think I got mine new from a seller on ebay.
http://www.jpcycles.com/product/744-...FUOXfgod61gA6g
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Mar 11, 2017 | 08:16 PM
Tadpole's Avatar
Tadpole
Stage I
Here's what worked for me: tallest windshield (23") and wind deflectors / fangs. Calm air around my full face helmet even at 80mph.
