Check Engine Light - Road King
Old Mar 28, 2017 | 09:27 AM
MedicUSA's Avatar
MedicUSA
Default Check Engine Light - Road King
Would a Harley throw out a Check Engine light if it had a blown fuse, tailight fuse to be exact??
2012 Road King FLHR
Old Mar 28, 2017 | 11:27 AM
Max Headflow's Avatar
Max Headflow
It might, Taillight power also powers the Speedo.. It will likely toss a code if the ABS fuse blows..
Old Mar 28, 2017 | 11:36 AM
nevil's Avatar
nevil
What code did you get?
Old Mar 31, 2017 | 05:53 PM
MedicUSA's Avatar
MedicUSA
Not sure about the code, but the check engine light came on the dash. I just recently upgraded my handlebars and internally wired everything. Checked all the lights and everything worked fine, BUT when I was putting on the switch housing I pinched one of the wires and shorted it to ground, blew a fuse. So I believe that was the reason for the light. I rode home right after that to check everything out and discovered the pinched wire problem. This happened last weekend and I haven't ridden since, its been cold as **** here in Michigan and rainy.
hyrax222
EVO
Sep 4, 2018 06:28 AM
panman4977
EVO
Jun 24, 2015 08:07 AM
Fugly
Aug 3, 2012 08:17 AM
dennis pitts
Jan 3, 2012 08:12 AM
HogMan
Oct 9, 2008 10:00 AM
