Lugging
Old Apr 12, 2017 | 10:24 AM
FATTURKEY's Avatar
FATTURKEY
2nd Gear
Default Lugging
Hi
I'm new to the forum.
Have a kinda stupid question to post but here goes.
Ride a Fatboy S which had S&S cams and high comp pistons installed over the winter.
Having just begun to ride after a long 3 months of Winter guess there were some cobwebs in my handling.
For one, I repeatedly lugged engine by using heal shifter thinking I was downshifting when actually I was upshifting.
Another time I stopped at a light forgetting to downshift into 1st; trying to start in 3rd gear from a stop is not good especially on this bike.
My question is , could there potentially have been any damage - considering the new pistons and cams?
Should I think about a compression test to see?
Thanks in advance
Old Apr 12, 2017 | 10:56 AM
the blob's Avatar
the blob
I believe if you made a habit of doing that all the time, then your engine life would drastically short. Once and a while it's no big deal.
Old Apr 12, 2017 | 02:06 PM
billib1954's Avatar
billib1954
Yes, it is damaged beyond repair. Send me your address and i'll have it picked up and disposed of properly in my garage. I assume you had some break in miles or a dyno break in after mods. You should be OK. I try to keep mine above 2k cruising, which is really easy with 30/70 sprockets.
Old Apr 12, 2017 | 02:33 PM
son of the hounds's Avatar
son of the hounds
You had to ride the clutch more starting in third.
Lugging is cruising at low rpm with a load on the engine. Starting off in the wrong gear, while technically lugging, is usually so embarrassing it does not hurt the engine.
In real lugging, low rpm and load on the engine, these are the things that can happen.
There is poorer oil circulation at critical areas at low rpm
There is more engine heat when lugging (less cooling)
There is less ability to maneuver, ie speed up to avoid an obstacle.
Gas mileage drops precipitously.
Your pipes sound awful
Engine life is reduced
Yet, Harley's provide enough low end torque so we all occasionally get seduced to play near the luggers edge sometimes. I have started off in second a number of times, don't know if I have tried third, but I agree with billib1954, your bike is trashed, only I'll come and take it off your hands.
Old Apr 12, 2017 | 04:13 PM
grbrown's Avatar
grbrown
No you haven't done any lasting damage IMHO. What you do need to do is engage brain and concentrate, to avoid repeating silly errors, otherwise you do risk damage!
Old Apr 12, 2017 | 11:19 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Nope, no damage to the bike. There will be significant damage to your Man Card though if you are caught doing this around other riders that notice your inability to get the bike into the proper gear!
Old Apr 12, 2017 | 11:22 PM
IdahoHacker's Avatar
IdahoHacker
I always keep mine under 1,000 rpm so I never damage the engine by over-revving. It's the only safe way to ride.
Old Apr 13, 2017 | 05:05 PM
Gozzie's Avatar
Gozzie
lol, too funny
Old Apr 15, 2017 | 05:21 PM
big- mike's Avatar
big- mike
Remove the heal shifter until your used to shifting. Now you only have to think about one shifter. Imho heal shifters just get in the way
Old Apr 15, 2017 | 08:17 PM
IdahoHacker
The *heel* shifter is the first thing I yanked off my bike.
Forget about whether or not you like how it shifts, the absolute worst part is that it locks your left boot into a small position, so you can't move your left foot forward and backward into different positions so you can relax.
Hate them suckers.
