Stalling while riding
Old Jul 15, 2017 | 07:24 AM
drflash63's Avatar
drflash63
3rd Gear
Default Stalling while riding
My 98 heritage springer stalls out after about 15 minutes of riding in 5th gear. After about 10 minutes it starts up. What is going on. I had replaced the breaker to no avail.
Old Jul 17, 2017 | 09:41 AM
Jchaiyo's Avatar
Jchaiyo
Does the bike crank but no start during that 10 minutes?
Old Jul 17, 2017 | 09:44 AM
drflash63's Avatar
drflash63
3rd Gear
Yes it cranks over but will not start
Old Jul 17, 2017 | 09:47 AM
Jchaiyo's Avatar
Jchaiyo
Ok, how old is the gas? What carb are you using? Have you tested the coils and the spark plug wires?
Old Jul 17, 2017 | 09:50 AM
drflash63's Avatar
drflash63
3rd Gear
fresh gas, cables are good. Unsure of coil. Was thinking maybe a short. It seems to keep tripping a breaker, once its cooled down (about10 mins) im good to go. Stock carb
Old Jul 17, 2017 | 09:52 AM
Jchaiyo's Avatar
Jchaiyo
What brand carb? How do you know it's tripping the breaker?
Old Jul 17, 2017 | 09:56 AM
drflash63's Avatar
drflash63
3rd Gear
The carb is a stock harley carb from 98. My cuzzin was a sevice manager for a dealership and suggested that might be the problem
Old Jul 17, 2017 | 10:07 AM
Jchaiyo's Avatar
Jchaiyo
Keihn carbs are bullet proof. But yes that could be your problem, float or voes comes to mind. So don't go pulling a perfectly good carb out for a s&s.
Still don't understand how you know the breaker is tripping.
grab a manual and see how to test your coils and spark plug cables .
All an engine needs is air, gas which is atomized, and a spark to work. If it stops getting one then your screwed. What worries me is it happens when engine is hot so therefore it could be a leak In the voes. It could be the float is not set to the correct height so it's not allowing enough gas to sit in the bowl. It could be the pingel. It could be the gas tank has rust in it. It could be coils are bad. It could be something else...
Old Jul 17, 2017 | 10:11 AM
drflash63's Avatar
drflash63
3rd Gear
it goes to the dealership on the 24th of july. I was kinda hoping its a quick fix situation. Thanks for all info
Old Jul 17, 2017 | 10:17 AM
Jchaiyo's Avatar
Jchaiyo
Damn bro just like that? Well I hope that they figure it out and your back on the road. I'm sure it will be a quick fix and they will take care of you. But while your down there, order a service manual even if your not mechanical. There is a lot of valuable info and you can learn to diagnose and do things on your own, even if it's not on your own you can keep the dealership honest with more knowledge you retain.
also please do post on here when you get the bike back, I'm really interested in finding out what's wrong.
good luck Dr flash
