Cleaning Tips
Old Jul 27, 2017 | 02:41 PM
Hartwig's Avatar
Hartwig
6th Gear
Thumbs up Cleaning Tips
What have you found to be the best cleaner to use on your bike, wheels and tires, engine besides harleys brand cleaners. Also what is the best to use on black vance and hines exhaust covers.
Old Jul 28, 2017 | 01:20 PM
Wisenheimer16's Avatar
Wisenheimer16
This stuff is great. You can use it on glass, plastic, rubber, chrome and paint.
Amazon Amazon
Old Jul 28, 2017 | 01:25 PM
Scrmnvtwins's Avatar
Scrmnvtwins
Wash with Dawn Dishwashing liquid, hot water then wiped down with a little McGuires liquid carnuba wax worked into a microfiber towel
Old Jul 28, 2017 | 07:19 PM
YPD485's Avatar
YPD485
Like you mentioned, after using Dawn to wash bike, you should apply some type of wax since Dawn strips all the wax off the bike.
Old Jul 29, 2017 | 07:39 AM
DelRider's Avatar
DelRider
Indeed. Most all detailing blogs that I recall reading say that dish soap should NOT be used on a regular basis and then only used in specific use scenarios. From Meguires himself:
From Twelve car cleaning myths On the CNN web site, Barry Mequiar says....
"Any dishwashing detergent is meant to remove everything from the surface," he says. "That will include stripping the polymers of the paint surface and the last thing you want the paint finish to be is squeaky clean."
Meguiar likens the effect of dishwashing detergent to what it does to someone's hands. "Too much detergent will dry the skin. On the surface of a car, the same thing occurs; dishwashing detergent actually accelerates the oxidation process when you use it on a regular basis."
And wax is not a substitute for the polymer coatings referred to.
To the OP, i think simple is better than relying on whiz-bang products. Hose the bike down to remove abrasive grit that will lead to swirl marks, wash down with any reputable auto soap and CLEAN mitt or sponge, then air dry with leaf blower to help prevent water spots (yes, I refuse to pay for some dedicated filtered air blower). Any good spray detailer after that or a twice a year waxing with a good cleaner wax. YMMV. Good luck!
Edit: no ideas for the VH black items, interested to hear what others use.
Old Jul 29, 2017 | 04:27 PM
eaglefan1's Avatar
eaglefan1
This! leave the dawn soap for dishes, don't use it on bikes or cars.
If you have a somewhat fresh coat of wax on the bike dawn will not strip it. What dawn does is leave residue behind that inhibits water beading from the wax
Use proper washing techniques, 2 bucket method if using a hose. 90% of the time I use Optimum No Rinse wash, no hose. I also use Backfire waterless wash for a quicker wash.
I detail cars as a sid gig and I don't use wax anymore. Use a sealant, last longer and it doesn't attract dust like wax.
Wax=Dust magnet
Old Jul 29, 2017 | 04:39 PM
eaglefan1's Avatar
eaglefan1
As for the pipes use a soap with no wax
Old Jul 29, 2017 | 04:50 PM
Rosco61's Avatar
Rosco61
Default Cleaner
https://www.amazon.com/Original-Spir...ner+%26+polish
That stuff is the best around. Been using it for years.
Old Jul 29, 2017 | 04:59 PM
CallMeChris's Avatar
CallMeChris
X2 on the optimum no rinse. Amazing stuff...and I've got a bottle mixed to the quick detailer dilution that I use for quick wipe downs between washes.
Old Jul 29, 2017 | 08:37 PM
eaglefan1's Avatar
eaglefan1
Here is my experience with bike spirits.
My bike is coated with 22PLE I'm going to say upfront. SO, if your bike isn't coated your results could/would be different.
I was on a over night trip and hit a lot of bugs on the ride that night. Woke up the next morning, walked out to clean the bike and my friend said try the bike spirits he had. I had waterless wash in the saddlebag but I like to try different detailing stuff so I read the directions and did the fairing. What a absolute greasy streaky **** show that was. I wiped that crap off the fairing as fast as I could and sprayed the waterless wash on right away. Never again! Terrible!
It might work great on other stuff but if you have a ceramic or quartz based coating on your bike stay away from that stuff.
Ill stick with 22PLE and a waterless wash. Waterless wash is way way cheaper than bike spirits.My buddy did half his fairing with bike spirits and half with the waterless wash I had. He asked if I would leave the WW for him and I did. He is done with the bike spirits
