Cb squelch issue
Old Sep 16, 2017 | 10:19 AM
Daviddddd's Avatar
Daviddddd
Stage I
Smile Cb squelch issue
Hi all. I am new to the group and I would be grateful for your support in addressing an issue with my CB. I have a 2016 Ultra Limited. Basically, I have to have the squelch set to a high level (14 bars) to stop it making me deaf! This happens on all channels even when the engine is not running.
I have set the INT VOX setting to a low level so I cant see that being the problem, and the radio is also on low volume, and is often off. I am not sure if this makes any difference but just in case!! The antenna is fitted on the correct side so I know that this is not the problem.
Your support and guidance would be very much appreciated.
Many thanks.
Dave
Old Sep 16, 2017 | 01:48 PM
bustert's Avatar
bustert
man i haven't fooled with cb radio in decades. the squelch cuts sensitivity, so which direction are you complaining about, traffic talk or snow??
has the antenna been tuned? (SWL). i am sure new ones are all digital inside these days but the old analog boards had pots that can be adj. best bet is to bring it to a cb shop.
Old Sep 16, 2017 | 02:57 PM
SPRINGER's Avatar
SPRINGER
Just out of curiosity, if your bike came with an owners manual, would there be something in there about your cb and how to make adjustments on it?
Old Sep 17, 2017 | 11:59 AM
roussfam's Avatar
roussfam
Originally Posted by bustert
man i haven't fooled with cb radio in decades. The squelch cuts sensitivity, so which direction are you complaining about, traffic talk or snow??
Has the antenna been tuned? (swl). I am sure new ones are all digital inside these days but the old analog boards had pots that can be adj. Best bet is to bring it to a cb shop.
swr...
Old Sep 18, 2017 | 09:59 AM
bustert's Avatar
bustert
correct SWR and not SWL dislexic fingers!!!
just because you bought it from hd as a system does not mean the swr is correct. this can possibly cause damage to the unit. meters are cheap these days. the newer antenna are not trim-able so there should be an electronic adj inside the unit. i ran two in my truck, one for smokey and the other to keep awake and position also makes a diff since the machine acts as a ground plane and the field will be elliptical.
Old Mar 27, 2019 | 08:31 PM
HDJIM1158's Avatar
HDJIM1158
I have the same problem with my squelch, Is there a vendor that you can send your unit to ??? Used to be a service that you could send your radio to....
RWP. JIM
Old Mar 28, 2019 | 03:28 PM
White Ice's Avatar
White Ice
Turn the volume down?
BlackUltraLimited
2014-2024 Touring Models
17
May 15, 2015 09:27 PM
cycleman50
Jul 17, 2013 11:43 PM
TowJam
Aug 13, 2012 01:29 PM
nmfxstc
Dec 16, 2008 08:19 AM
mhonn2220
Nov 26, 2008 03:20 AM
