Gas Tank Compatability/Conversion
Old Oct 24, 2017 | 01:38 PM
dollarbill7's Avatar
dollarbill7
3rd Gear
Default Gas Tank Compatability/Conversion
I have a very high end and personal paint job on my 1999 Road King Classic (FLHRCI Magneti Marelli injection) that I blew up the engine on. I am considering getting a very clean, low mileage 2004 Road King Classic (FLHRCI Delphi injection) to put my custom body work on. I have read that the tanks are not compatible...I'd like to know if that's true and if it is, is there a conversion set-up?
Old Oct 25, 2017 | 10:39 AM
grbrown's Avatar
grbrown
I have a 2009 RG tank on my 1990 Glide. With a little determination I'm sure you can make the swap, but I suspect you will have to work out the conversion yourself, as I did. My bike is carb, so I didn't have the EFI pump etc to swap over. The official H-D way is to describe things that are a direct swap, however that doesn't mean things can't be swapped around, using a little ingenuity. You may get more feedback over in the Touring forum.
Old Oct 25, 2017 | 12:04 PM
dollarbill7
3rd Gear
Yeah, That's what I was thinking...the only thing was going from one efi tank to a different system...Thanks for the feedback and I'll post it in Touring as well!
dollarbill7
Oct 27, 2017 01:34 PM
dollarbill7
Oct 25, 2017 12:07 PM
Baxterdog
Aug 9, 2014 11:09 AM
KingsJester
Powdercoat & Paint
Sep 15, 2011 05:30 PM
smokeyhumper
Dec 11, 2006 12:52 PM
