Friggin' star screws?????!!!!!
Old Jun 16, 2007 | 11:40 PM
RKCustom07's Avatar
RKCustom07
Default Friggin' star screws?????!!!!!
Can anyone tell me if there is an actual tool available to remove the star screws with the pin in the middle of the star? Or, is there a known method of removing them (in example, from the exhaust pipes). Thanks for any help you can give.
Old Jun 17, 2007 | 01:46 AM
vertigo14's Avatar
vertigo14
Default RE: Friggin' star screws?????!!!!!
thoes are tamper proof torx bolts...(pretty lame if u ask me)
Old Jun 17, 2007 | 04:40 PM
RKCustom07's Avatar
RKCustom07
Thank you very much, I really do appreciate the response. I stopped by my local Bennett Auto Parts store after church and found a a set of the Tamper Proof (Torx Bits) Star Bits.
Old Jun 19, 2007 | 10:50 AM
EVOrider's Avatar
EVOrider
I hate torx, but especially hate tamper proof torx. The TPS on my 98 Ultra is held there with tamper proof.....the only tamper proof torx I have found on the bike anywhere.
Old Jun 21, 2007 | 07:16 PM
thelawdoc's Avatar
thelawdoc
Vertigo, got a link for that torx set?
Old Jun 28, 2007 | 02:42 PM
atillman's Avatar
atillman
I found a real in-expensive set at Harbour Frieght. Only a buck or two. They are cheap but if you only use them once or twice they are great.
Old Jun 28, 2007 | 05:29 PM
thrillseeker's Avatar
thrillseeker
I've bought all my torx and hex bits from these guys (t handles, 3/8 socket, etc)
http://www.wihatools.com/
I found most torx bits are poorly made and the tips tend to break. These guys make a pretty high quality product for a fair price. I've done numerous orders from them without issue.
They call the tamper proof torx "torx security tools"
Old Jun 29, 2007 | 08:18 AM
peppi's Avatar
peppi
I've found that if you take the bits and use the side of a grinding wheel and grind them flat as opposed to the rounded config that they come with , it works better and you don't run the chance of stripping the bolt out either because it seats deeper into the bolt.
Old Aug 9, 2007 | 01:20 PM
flyslow's Avatar
flyslow
You can also get the individual torx bits at any grainger supply house. . .they are about 2 dollars each.
Old Aug 12, 2007 | 03:46 PM
MNPGRider's Avatar
MNPGRider
EVORIDER, what's a TPS? I looked all over my '06 Ultra and don't find any Torx bolts that have that head.
One of the things I've been amazed at, is the incredible amount of torque necessary to break loose the bolts on anything on my Ultra. I had to use an impact driver to get the saddle bag trim rail loose, as an example, to install a trailer hitch.
