air cleaner insert question
Old Jan 30, 2018 | 10:56 AM
jake2351's Avatar
jake2351
Default air cleaner insert question
I want to remove the insert on the stock air cleaner housing its slightly damaged how is it attached to the housing? double sided tape or glue? is there an easy way to remove it without scratching up the chrome on the cover? thanks
Old Jan 30, 2018 | 11:39 AM
nevil's Avatar
nevil
Don't know what bike you have and also don't know if it matters, but from what I've seen it is glued on. Use heat, either a hair dryer or gently use a heat gun. It's easier if you take the cover off first.
Old Jan 30, 2018 | 12:15 PM
jake2351's Avatar
jake2351
my current HD is a heritage soft tail thanks for the tip ill give it a try this afternoon.
Jack Straw
May 11, 2011 07:57 PM
creatv1
Jun 11, 2010 11:46 AM
FGC
Apr 24, 2008 10:34 PM
jesserocket01
May 2, 2007 12:23 PM
four5acp
Exhaust System Topics
Aug 13, 2005 03:13 AM
