Help!!!!!!
Old Mar 8, 2018 | 07:57 PM
Sam Henning's Avatar
Sam Henning
Stage IV
Default Help!!!!!!
I have an 07 Electra Glide stage one, 2into 1 other then that stock .I am chasing a problem. I am having loss of power when I rip on it and 3000 RPM and up. Pulled fuel system out and found a pin hole on fuel line replaced that. Problem still there. Replaced fuel filter still here. Replaced battery annnddd still there. Tested fuel pressure 60 at idle at 55at high RPM. Thoughts???? Riding season is coming up soon.
Old Mar 8, 2018 | 08:19 PM
golfblues's Avatar
golfblues
You do have a fuel management device with those pipes and stage one correct? Maybe a corrupt map.
Old Mar 8, 2018 | 08:27 PM
MURPHCC1's Avatar
MURPHCC1
Injectors clogged?
Old Mar 8, 2018 | 08:35 PM
QC's Avatar
QC
What gear are you in at 3000 RPM when you whack the throttle open?
Old Mar 9, 2018 | 06:25 AM
grbrown's Avatar
grbrown
Have you made the changes to stage 1 yourself? If so fuelling may be out.
Old Mar 9, 2018 | 11:18 AM
Sam Henning
Stage IV
Lower gears have with the cold here I have not gotten it up to the higher gears.
Old Mar 9, 2018 | 11:19 AM
Sam Henning
Stage IV
No I got the bike last year with the stage 1 already to put in.
Old Mar 9, 2018 | 02:21 PM
Ed Ramberger's Avatar
Ed Ramberger
Does it feee like the brakes are on when you let off the throttle?
Old Mar 9, 2018 | 02:23 PM
Sam Henning
Stage IV
No, I am getting no abnormal sounds or smells. The only time I can feel the problem is 3000 RPM+
SoonerSoftail
Oct 19, 2015 05:29 PM
bigdog1949
Jul 1, 2014 06:36 PM
nervousnorm
Exhaust System Topics
Sep 25, 2011 06:01 PM
milfly
Jul 12, 2010 06:14 PM
ronyd
Sep 15, 2008 05:58 PM
