s@s super E
Old Mar 18, 2018 | 11:39 AM
Jeff Fish's Avatar
Jeff Fish
Default s@s super E
Helllo my evo has a headquarters cam , v@h long shots and altima single fire ignition . I palan on replacing the carb with a super E than get it on the dyno . Do I have to replace the cables ? Is this to much carb ? Any input would be helpful thank you Jeff
Old Mar 18, 2018 | 05:11 PM
98hotrodfatboy's Avatar
98hotrodfatboy
No. The E is very versatile. I have one on my 74"shovel and used to run it on my 80" Evo. Now I have the G on it.. For the Jets a good starting point would be a .0295" on the intermediate and a .070" on the main... 1 1/2 turns on the idle mixture and 2 full turns on the accelerator pump....
Old Mar 18, 2018 | 05:50 PM
Jeff Fish's Avatar
Jeff Fish
thank you for the help . is it best to order the manifold in the kit or use the existing HD one ?
Old Mar 19, 2018 | 05:42 AM
98hotrodfatboy
You never stated what year and model. If you have 2 throttle cables it won't be an issue. Just follow S&S's directions. You will need the manifold in the kit.. It will not bolt up to the OEM intake.
Old Mar 20, 2018 | 06:02 AM
grbrown's Avatar
grbrown
Wink
Jeff, for future reference you will find there is a dedicated Evo section, where you will find fellow owners and S&S fans! Call by....
Old Mar 20, 2018 | 10:20 AM
Max Headflow's Avatar
Max Headflow
SnS has 2 cable brackets that allow you to use your stock cables depending on whether you are running the old (butterfly only) or new (CV) Keihin carb. On the later CV carb replacement, if the stock cables are short from the carb to the bars you might need to find longer ones as the cables run to a different location on the E compared to the CV. E is fine for an 80 ci Evo motor. Year would be helpful here.
jon loder
Shovelhead
Apr 19, 2017 10:08 AM
flhsport
EVO
24
Feb 3, 2017 09:34 PM
Heathicus
Carburetor Related
Mar 27, 2011 06:30 PM
byg twyn 55
May 23, 2010 01:10 PM
raven28690
Ironhead
Mar 4, 2007 02:40 AM
