General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
The only reason I am answering a first post without any sort of introduction is the dead hamster made me laugh.
Does it chirp when you get on and off the throttle too? Chirping is many times a loose belt. It can be verified by checking belt deflection or spraying the belt with water and seein if it goes away temporarily. .
Only chirps when releasing the clutch, only when tromping on it. theres nothing in second, third or fourth. just in first. checked the belt and its good
Maybe it's got so much motor it's chirping the tire. Better unhook one plug wire on that bad boy before someone gets hurt!
