Evo intake on a twin cam?
Old Jan 22, 2019 | 03:22 PM
JAMIECONYERS's Avatar
JAMIECONYERS
6th Gear
Default Evo intake on a twin cam?
So here’s my dumb question for the day. Will an evo intake manifold fit on a twin cam 88? I have a 2003 fatboy that I’m converting from efi to carb. I’m looking to install a super e on it and I’ve heard of people using evo intakes on tc engines. Am I in the right ballpark?
Old Jan 22, 2019 | 08:13 PM
Mattbastard's Avatar
Mattbastard
According to all my research, yes it'll bolt up. One of my future projects is an EFI conversion on my 1994 Road King using a 2004 Ultra throttle body and Microsquirt. All the research I did says it'll bolt up.
Have I ever done it? no.
Old Jan 23, 2019 | 08:57 AM
Max Headflow's Avatar
Max Headflow
I've use Evo G manifolds on TCs.. They only thing you need to do is drill the boss for the MAP sensor. If the Evo manifold is early enough it won't have the boss. You can still install the map sensor you need to mill a flat. Sealing area gets kind of thin..
Old Jan 23, 2019 | 10:55 AM
JAMIECONYERS
6th Gear
This is the first time I’ve heard the term “Evo G”. I’m assuming this is a later style evo engine. I’m doing a complete ecm delete and using a stand alone Thunderheart ignition , so I won’t be using the MAP sensor. So does that mean any evo intake will work?
Old Jan 23, 2019 | 11:45 AM
misfitJason's Avatar
misfitJason
Evo G is a evo s&s super g carburetor
Old Feb 9, 2021 | 11:29 AM
xcbullet's Avatar
xcbullet
Has can be seen the fuel rail is way different
I think the bore is different too and injector
Old Feb 9, 2021 | 11:45 AM
roussfam's Avatar
roussfam
Well, he's had two years to figure it out
Old Feb 10, 2021 | 01:04 AM
xcbullet's Avatar
xcbullet
Its the great related thread, wish they would get rid of that.
SupaDave
Aug 7, 2013 07:52 PM
motorwolf
Jun 5, 2011 09:52 AM
motorwolf
Exhaust System Topics
Jun 4, 2011 08:55 PM
legendzzz
Oct 8, 2010 03:36 PM
plivez
Dec 2, 2009 10:12 PM
