Front Signal Lights
Old Jul 7, 2007 | 12:32 PM
jopeck11's Avatar
jopeck11
5th Gear
Default Front Signal Lights
I have a 2000 XL1200 Sportser. Went to replace front signal lights with after market lights mounted on front forks.
Found signal wire, but will not flash new signal lights, unless they are wiredin withthe factory signal lights.
Using a test light it will not flash unless factory lights arehooked back up on the signal wire.
The 4-way flashers will flash the new signal lights.
Any help would be greatly appreciated.
Thank you in advance.
John Peck
Old Jul 7, 2007 | 12:56 PM
wesd41's Avatar
wesd41
Default RE: Front Signal Lights
What aftermarket lights are you trying to install (brand, type, etc). LED and some small, low draw bulbs won't work without load equalizers.
Old Jul 7, 2007 | 03:13 PM
jopeck11's Avatar
jopeck11
5th Gear
They are not LED signal lights. They are 2 bulb amber just like in the J&P catalog, pg. 392 - item #3300761.
Thanks, John
Old Jul 7, 2007 | 03:27 PM
jopeck11's Avatar
jopeck11
5th Gear
They are 2 wire, 2 bulb, single filament bulbs, amber lenses. They are 2 3/4" long x 1" wide.
Thanks, John
Old Jul 7, 2007 | 06:40 PM
wesd41's Avatar
wesd41
Those are mini-bulb lights and draw too low to work your signals- try a load equalizer, page 396-397 in the 2007 J&P catalog.
Old Jul 7, 2007 | 08:24 PM
jopeck11's Avatar
jopeck11
5th Gear
wesd41,Thank You for the info,I will try that,John
Old Jul 13, 2007 | 07:21 PM
jopeck11's Avatar
jopeck11
5th Gear
Installed a load equalizer from J&P ( Smart Equalizer), plug in installation, problem corrected,Thanks again wesd41,John
Old Jul 13, 2007 | 07:58 PM
wesd41's Avatar
wesd41
Cool, glad it worked out for you.
roussfam
Oct 12, 2010 07:19 PM
Big Rol
Feb 20, 2010 08:53 AM
Cakalac
Mar 9, 2009 12:49 PM
jamesf0622
Aug 6, 2008 11:47 PM
charliebravo
Mar 3, 2008 03:44 PM
