Correct torque setting
Old Apr 4, 2019 | 03:04 PM
barneyboy's Avatar
barneyboy
Originally Posted by ohioflhs
This has absolutely nothing to do with the original post.
I'm sorry, I was under the impression the thread was about "Correct torque setting".
So, if I torque my rear axle to 95 ft-lbs (95-105 recommended) with my recently calibrated wrench, and the following day I check it per the FSM, and it doesn't rotate at the minimum setting (95 ft-lbs), the torque has been maintained. What's the point of torqueing to 100 ft-lbs (midway), other than compensating for the inaccuracy of an inexpensive wrench, when 95 ft-lbs is within spec?
Old Apr 4, 2019 | 03:16 PM
bustert's Avatar
bustert
mr. dan said it all!!!
the fsm knows not what you do, only a guideline.
Old Apr 4, 2019 | 06:21 PM
barneyboy's Avatar
barneyboy
Originally Posted by bustert;18158335[b
]mr. dan01/28/2019 said it all!!!
The FSM is an innate object, and therefore is incapable of knowing what you do, or what you do not do. Let the OP sort the replys, and formulate his own conclusion.
HOG_0308
Jul 18, 2010 11:01 PM
xd.404life
Jun 11, 2010 07:17 AM
wolfydude
Feb 21, 2009 12:04 AM
twilliams
Jun 20, 2007 10:16 AM
CobraKid
Nov 3, 2005 12:48 AM
