Stiff Brakes Sporty 1200xl
Old Jun 11, 2019 | 02:13 PM
JHeimann1313's Avatar
JHeimann1313
Stage I
Exclamation Stiff Brakes Sporty 1200xl
so i hate to say it but i laid my bike down taking a turn ran off and down she went on the right side. all was alive and rode 30 min home, and 2 things.
my brakes are now stiff and harder to pull back. still have a full master cylinder and no leaks. plates arent locked up at all.. thought about trying to drain, fill and bleed them... not sure what could be causing this other than i laid it down on that side
also i have the red security light on and this model didnt come with a fob and dont know how to get rid of it without taking it to the dealer...
and help or thoughts appreciated, thanks for checkin this out.
---RideOn
Old Jun 12, 2019 | 08:36 AM
bustert's Avatar
bustert
distorted lever. make sure the rotor run out is still good.
what year. might try powering down the machine. that should remove the soft code but the hard code will remain and will require a scan tool to erase but after so many start cycles without repeat, these usually go away.
bikermike65
Wheels/Tires
Jan 17, 2014 08:58 AM
bikerlaw
Aug 18, 2013 08:53 AM
Steve Leonard
Mar 11, 2012 09:54 AM
Divermsb1
Wheels/Tires
May 27, 2010 04:53 PM
JSW
13
Aug 14, 2006 10:02 PM
