Burnout damage 2000 softail
Old Jul 15, 2019 | 08:56 AM
kellie hall's Avatar
kellie hall
Stage I
Default Burnout damage 2000 softail
Have done a couple mild burnouts on my Heritage Softail. Now it is making a ticking noise. It sounds to me like it is the adjustable pushrods but I am not sure. Can anybody give me any advice? Thank you
Old Jul 15, 2019 | 09:01 AM
touchdown204's Avatar
touchdown204
so what the hell is burn out damage?? Could be valve adjustment, cam tenchener ( I know poor spelling.)
Old Jul 15, 2019 | 09:18 AM
Jackie Paper's Avatar
Jackie Paper
You 2000 is subject to ripping the 10 splines out of the alternator rotor. Especially if you are smoking the tire and it hooks up suddenly. What mine did years ago when someone was smoking it on a worn out tire and it blew. However, the tick it had only developed after a lot of slipping of the rotor and as it wore steel to steel, it let the primary sprocket move over and the alignment started nipping chain as slow speed and in a left hard-turn.
If you are referring to at idle tic, get you a two ear Harbour Freight Mechanic stethoscope and figure out where tic is. You can't just stand back or use a screwdriver. Just too much other racket and sound travels thru metal.
Do you suspect the pushrod adjustment came loose?
Old Jul 15, 2019 | 09:40 AM
joe40x's Avatar
joe40x
Ahhh...stop doing burnouts?
Old Jul 15, 2019 | 11:12 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Either stop doing burnouts, or learn to repair the damage you do...
A ticking noise, all you can do is try to narrow down the area, and then start disassembly and inspect.
Easy stuff first.
Old Jul 16, 2019 | 06:17 PM
Sparkee...'s Avatar
Sparkee...
I had a little burnout damage in the '70s... or was that the '80s...
But I'm OK now.....
sno-man
May 10, 2016 05:07 AM
Oldfart666
Jan 10, 2014 07:39 AM
wedgehead
Sep 12, 2012 07:13 PM
clearsky2007
Motorcycles For Sale
Jun 21, 2007 07:42 PM
mhultman
Nov 4, 2005 07:27 AM
