2000 softail vibes???
Old May 9, 2016 | 07:34 PM
sno-man's Avatar
sno-man
Default 2000 softail vibes???
Hi Guys, i got a 2000 Heritage softail 88b motor, I notice that it i has vibration when u rev it up. It use to have no vibes, so i checked the engine mounts notice the top one was loose, tightend that, little less vibes, better, but it still has some when i rev it up i notice the front wheel hopps alittle at a certain rpm. what should i check next? It runs good, makes no noises. i was thinking about looking at the compesator????? what do you guys think? thanks
Old May 9, 2016 | 08:47 PM
rmc115's Avatar
rmc115
Sounds like the balancer gear on the crank may have slipped. it is only a press fit and can slip on the crank causing the balance shafts to vibrate out of time. This is not possible to check without disassembly so you will have to check everything else first. Mike
Old May 10, 2016 | 05:07 AM
sno-man's Avatar
sno-man
Hi, Thanks for the reply, Would checking the balancer entail taking off the primary and the clutch, the compensator, the flywheel, then the balancer? I have a book didn't look at it to much, does the balancer have some dots to keep it in line when installing. o forgot bike has 41000 miles. thanks for the help
tigercreek
May 5, 2016 02:09 PM
Oldfart666
Jan 10, 2014 07:39 AM
wedgehead
Sep 12, 2012 07:13 PM
clearsky2007
Motorcycles For Sale
Jun 21, 2007 07:42 PM
darkglide
Exhaust System Topics
Aug 4, 2006 02:56 PM
