vibration
Old Jul 31, 2006 | 03:54 PM
darkglide's Avatar
darkglide
2nd Gear
Default vibration
i have a severe vibration at 2000 rpm. you feel it in the foot pegs and handle bars.it will do it sitting in neutral also at 2000 rpm. it's an o5 superglide and i really didn't notice it that much last year. i know these things shake but this seems to be more severe to me. is it normal? i checked the motor mounts and they look good.
Old Jul 31, 2006 | 04:29 PM
Spectrexx's Avatar
Spectrexx
Default RE: vibration
If your motor mounts are all tight, check your primary chain adjustment. Also check your VOES switch, plugs, wires, etc. Is it ONLY at 2000 rpm, not 2100 or 1900? If it's doing it sitting still, set the rpm to 2000 and feel around the bike for something that might be loose.
Old Jul 31, 2006 | 04:46 PM
darkglide's Avatar
darkglide
2nd Gear
it's just at 2000.it goes away above or below that rpm.i haven't checked the chain yet. i've been thinking of putting in an automatic tensioner.btw what's the voes switch do? i put new handlebars on this year could i have screwed something up there?
Old Jul 31, 2006 | 08:59 PM
Spectrexx's Avatar
Spectrexx
The VOES acts like the advance mechanism in a car. It senses engine vacuum and advances or retards the ignition to allow the best performance. It's either on or off, depending on the amount of vacuum in the intake manifold. It should be connected to the intake manifold by a hose. You can read up on it in your factory service manual.... hope ya got one! It's a necessary "tool" for every Harley owner.
Old Aug 3, 2006 | 07:59 PM
onephsyco1's Avatar
onephsyco1
How do you inspect the motor mount ?
Jack
Old Aug 4, 2006 | 02:56 PM
Spectrexx's Avatar
Spectrexx
You inspect it like you inspect everything else.... by looking at it. [sm=smiley17.gif] See if there are any cracks, and check the torque on the hardware.
Sometimes when something is loose, it will vibrate more only at certain frequencies (or engine speeds).
TurboGliding
Sep 13, 2017 06:43 PM
sno-man
May 10, 2016 05:07 AM
Ghosty
Jun 29, 2011 07:01 PM
lunyty1
Jul 23, 2010 02:54 AM
KBFXDLI
Aug 5, 2007 04:22 PM
