General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
I have a 2019 SGS and I had the bike up on a platform jack installing a cool flow fan and a fan assisted oil cooler. We'll as soon as I'm done one of the ratcheting straps I was using to secure the bike fail and the bike laid over. I picked up the bike and everything seemed fine. Well I decided to let the bike sit over night so that I could check the oil lever after changing out the oil cooler and it looked good. When I went to turn on the bike the oil light came on. It doesn't have low oil I double checked so I'm lost as to why it's on. Any ideas? Looking online maybe the oil pressure switch got damage when it fell over?
Check the sensor and wire for damage. Unplug the sensor and see if the light is still on with the engine running. If so, the Wire may have gotten pinched somewhere between the sensor back to the light. If not sensor probably damaged.
Where is the sensor located? Right under the oil filter or somewhere around there I'm presuming?
