replace clutch cable when?
Old Sep 12, 2019 | 09:08 PM
fjkpan's Avatar
fjkpan
6th Gear
Default replace clutch cable when?
I have a 2014 flstc with 56000 miles. No issues. Just wondering however when do most feel it tiime to replace the clutch cable? Mine seems fine but--
Old Sep 13, 2019 | 06:42 AM
grbrown's Avatar
grbrown
No simple answer to that! What I have found is that in time any cable can start to get sticky, or feel tighter than it once was. If lubricating it doesn't improve things, then by all means replace it. In my case I upgraded my engine and clutch a few years ago, so had a heavier clutch pull. I tried various ways of reducing the pull, but eventually found a new H-D Diamondback cable did the trick. It is remarkable how much lighter and smoother it is! I'm not sure they are still available, but I understand Barnett make a similar one.
Old Sep 17, 2019 | 08:59 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I replaced the original clutch cable on my `89 Softail when it was 25 years old (about 125,000 miles).
I only replaced it because it was so old, it was still working fine. OEM cables are very good stuff...
Sometimes a cable will tell you when it is time to replace it, if you notice any increase in resistance in a clutch or throttle, make sure you investigate as soon as you can.
Old Sep 17, 2019 | 05:19 PM
dawg's Avatar
dawg
When it needs it. Routine maintenance goes a long way.
Old Sep 27, 2019 | 10:31 AM
xcbullet's Avatar
xcbullet
136.000 on mine once a year I put grease on the cable where it goes in the outer part, it has a groove worn there. First I try to get some lube down it but the grease makes the biggest difference.
Old Oct 1, 2019 | 03:01 PM
ScottyMoore's Avatar
ScottyMoore
I lubricate the Clutchcable with a shot of "Ballistol", once a year.
Works fine with throtlecable to.
Greetings from Munich!!!
Richard Winquest
EVO
Jun 15, 2017 06:45 PM
xskuzame
Oct 6, 2014 09:12 AM
Cornel
Aug 20, 2012 03:52 PM
Dieselhed
Aug 9, 2009 06:12 AM
skos
Oct 23, 2008 03:46 PM
