Engine stalling issue 2000 fxdx
Old Feb 4, 2020 | 09:30 PM
BayBridgeFxdx's Avatar
BayBridgeFxdx
5th Gear
Default Engine stalling issue 2000 fxdx
Ok guys I’m looking for some advice... bike won’t stay running. It will warm up fine for a few minutes until warm. Once warm it will run for 30 seconds and then stall regardless if at idle or throttle. At throttle I can feel noticeable power loss for a split second before the stall happens. I do not lose headlight power, gauge lights or any other noticeable power. It will only crank over and not fire until I flip the ignition off and back on, then it will fire up again. So far I have
1. tested battery/charging system (everything checked out)
2. replaced the crank position sensor
3.Plugged in an alternate ignition coil
4.Tested the ignition switch terminals for continuity after the bike died before cycling the key off/on
5. Replaced MAP sensor
I have replaced the petcock with a pingel, so the vacuum actuated petcock is not the issue. It seems to be heat related as the stalling only happens after the heads are warm to the touch. I’m running a 95” with a Mikuni 42. This problem happened intermittently on freeway rides for 2 days, and now the bike will not stay running when warm.
Has anyone had any experience with a similar issue?
Old Feb 5, 2020 | 06:57 AM
jbarr1's Avatar
jbarr1
Bank angle sensor.
Old Feb 5, 2020 | 07:32 AM
98hotrodfatboy's Avatar
98hotrodfatboy
32793-00 cam timing sensor.. typical of a hall effect switch. When they get hot they fail..
Old Feb 5, 2020 | 05:21 PM
BayBridgeFxdx
5th Gear
I thought about replacing that when I replaced the Crank position sensor... Harley has one in stock so I’ll get it installed tomorrow after work
Old Feb 5, 2020 | 06:02 PM
98hotrodfatboy
If you don't already, I would invest in a Factory Service Manual.. it'll be your best friend..
Old Feb 5, 2020 | 11:09 PM
BayBridgeFxdx
5th Gear
Well it looks like the cam position sensor might be discontinued. I’m having a hard time finding an aftermarket part, and can only find the O rings. If you have any advice on where to find one I would appreciate it
Old Feb 6, 2020 | 10:22 AM
98hotrodfatboy
Suffolk County Harley Davidson on Long Island has one on there shelf. $79. 631-244-9000. They also said it's a good part number so you shouldn't have an issue finding it
Old Feb 6, 2020 | 08:26 PM
BayBridgeFxdx
5th Gear
So I installed a new cam position sensor and am still having the same issue
Old Feb 6, 2020 | 08:35 PM
Mattbastard's Avatar
Mattbastard
How did you manage to find a discontinued part in one day?
Old Feb 6, 2020 | 08:38 PM
BayBridgeFxdx
5th Gear
called around and drove out to the valley to get one
