Air Intake help??
Old Apr 25, 2020 | 09:35 AM
SGSRogo's Avatar
SGSRogo
Default Air Intake help??
Noob here. Can anyone tell me what intake this might be? I want to replace the football cover and Im not sure what to get. TIA.
Old Apr 25, 2020 | 09:45 AM
QC's Avatar
QC
Looks like an Arlen Ness Big Sucker. Just a guess, though.
Old Apr 25, 2020 | 10:54 AM
MyFavRk's Avatar
MyFavRk
Here you go .... you can order a round cover and fastening bolt .... Just measure the diameter of the filter before you order it and you should be good to go .
http://www.dkcustomproducts.com/nake...-dk-fm-pbn.htm
http://www.dkcustomproducts.com/inte...rs-c72-254.htm
Old Apr 25, 2020 | 12:23 PM
nevil's Avatar
nevil
If you take off the filter there should be some markings that tell you what it is, but it does look like a Big Sucker.
Old Apr 25, 2020 | 02:11 PM
MyFavRk's Avatar
MyFavRk
The Arlen Big sucker doesn't have the external breathers , they are set up to breath internally through the throttle body . This one shows the breather hoses going in behind the TB plate . The link I provided shows the exact set up you have .
Nevil is correct , pull the air cleaner off and see if there are any markings / model #'s .
Old Apr 25, 2020 | 05:00 PM
SGSRogo's Avatar
SGSRogo
Default Air Intake
So say I want to change to the Arlen Ness Inverted Series air cleaner, would there be an issue?
Old Apr 25, 2020 | 06:29 PM
MyFavRk's Avatar
MyFavRk
If you wanted to switch over to a AN Inverted , you would have to remove that air cleaner / backing plate that you have and start fresh . Order an entire kit , at least , that's the only way I can see you getting it done . You could also call DK and see if they offer a different air filter for your backing plate , and purchase an inverted cover to go with it , that I'm not sure about .
8200rpm
Engine Mechanical Topics
Apr 24, 2020 08:15 PM
RedOregon
14
Sep 25, 2019 11:04 AM
peterjamesbenson
Dec 6, 2016 02:17 PM
Village Idiot™
Mar 8, 2013 09:14 AM
jrdn003
Nov 6, 2011 08:26 PM
