Having issues with getting the bike to start
Old Apr 26, 2020 | 10:55 AM
Rocking_it's Avatar
Rocking_it
Yep my bet is old fuel. Spark shouldn’t go bad from sitting.
Old Apr 27, 2020 | 09:02 AM
TexNorth's Avatar
TexNorth
How long was it in storage? Sounding like fuel......
Spark is quick and easy to check......
Old Apr 27, 2020 | 02:03 PM
ak_47's Avatar
ak_47
6th Gear
I checked the spark plugs and one of them gets a good blue spark, but the other is a yellow spark. Also, I noticed there is air coming out of the cylinder head, is that normal?
Old Apr 27, 2020 | 02:04 PM
ak_47's Avatar
ak_47
6th Gear
It was in storage for 3 months. But I rode it one time before I started having issues with the battery and whatever is causing it not to fire up.
Old Apr 27, 2020 | 02:06 PM
ak_47's Avatar
ak_47
6th Gear
Originally Posted by Yankee Dog
How old is the fuel? Any fuel stabilizer before storing? I agree with others, check for spark. But tell us about the fuel.
The fuel might be old. I did not put any fuel stabilizer because I didn't plan on it going to storage. Check spark and one is blue and sparking, the other is sparking but its yellow.
What should I do about the fuel? Drain it and put in some new fuel?
Old Apr 27, 2020 | 06:12 PM
MyFavRk's Avatar
MyFavRk
If your referring to the air coming out of the spark plug hole , then yes , perfectly normal , just the compression stroke .
The weak spark could be a faulty wire going to the coil , check your connections , if good , then I would test your coil and see what readings you get .
https://itstillruns.com/test-harley-...l-6516657.html
Old Apr 28, 2020 | 11:18 AM
Yankee Dog's Avatar
Yankee Dog
Yes, drain old fuel, add fresh fuel. Might take a bit to get the new fuel into the injectors or carb. So don't expect immediate results. Get a new set of plugs and repeat the "check for spark". YD
Old Apr 28, 2020 | 01:46 PM
ak_47's Avatar
ak_47
6th Gear
I will check the coil and all the connection tonight and see what readings I'm getting. Thanks!
Old Apr 28, 2020 | 01:47 PM
ak_47's Avatar
ak_47
6th Gear
Sounds like a good plan. I'll start on that tonight and see what results I get. Appreciate it.
Old Apr 28, 2020 | 09:33 PM
MilsurpShooter's Avatar
MilsurpShooter
You mentioned you replaced all your fuses... Sure they're all seated properly?
