Choke
Old Jul 25, 2020 | 11:36 PM
cgmartine's Avatar
cgmartine
Angry Choke
I found out today that when I pull the choke on my 2000 Heritage Springer (107 CI Screaming Eagle), it springs back by itself about 2/3 of the way back in. It acts as if it has a spring return, but I do not believe a spring return is incorporated. So it appears that all the time that I thought the choke was fully out, it was only out part of the way. I will now have to hold the choke out as long as necessary to ensure I actually have the choke fully activated. Also, I would urge those of you who have a zip tie attached to the choke mechanism to secure one the spark plugs wires, that you check to make sure that the tie down does not interfere with the free movement of the choke staff, preventing it from fully seating.
Old Jul 26, 2020 | 07:02 AM
dawg's Avatar
dawg
Why not fix it?
Old Jul 26, 2020 | 07:21 AM
grbrown's Avatar
grbrown
Exclamation
Woah there! Take a closer look at your choke **** and you will find that you can adjust the tension on it, to hold it open. Easy-peasy! Should be in your FSM.
Old Jul 26, 2020 | 11:29 AM
cgmartine's Avatar
cgmartine
Thx. I just looked up the procedure. Since this is a new to me bike, I am still learning about its operation.
Old Jul 26, 2020 | 11:40 PM
Clammy's Avatar
Clammy
There actually is a spring at the end inside the carb. As mentioned above, you can adjust the tension at the bracket where it's mounted on the left side. The way I do it is to loosen the nut on the back side of the bracket, tighten the plastic collar on the front as much as I can with my fingers, then re-tighten the nut on the back. Stays put all the time. And if vibration loosens it, I just repeat the procedure.
Cheers!
Old Jul 27, 2020 | 01:21 PM
Mattbastard's Avatar
Mattbastard
Yea, tighten that tension adjuster. Worst case scenario, buy a new one for like $20.
Old Jul 27, 2020 | 01:46 PM
Uncle Larry's Avatar
Uncle Larry
The answers are always so easy when you know them ... I take "geniuses" for $400.00 Alex :>)
Old Jul 28, 2020 | 11:35 AM
Yankee Dog's Avatar
Yankee Dog
Careful not to over tighten and break it! The treaded portion is hollow plastic...
Old Jul 28, 2020 | 01:38 PM
Mattbastard
Final Jeopardy category: Harley Davidson Carburettors
Question: This manufacturer designed and manufactured a 40mm constant velocity carburetor for Harley Davidson from the early 90's up until the mid 2000's when they fully converted all their motorcycles to fuel injection?
Old Jul 28, 2020 | 01:41 PM
Screamin beagle's Avatar
Screamin beagle
What is keihin? Not sure on that spelling Alex
