Petcock question
Old Dec 5, 2020 | 10:51 AM
tinymike66's Avatar
tinymike66
Default Petcock question
Hello,
any one know if there's any other petcocks other than pingel that will fit the pingel MM to carb tank conversion kit.
I bought a drag specialty but the filter is to big and won't slip through adapter.
If not, which Pingel petcock (part #) do I need
2001 HD Ultra MM to Carb conversion
Thank you
Old Dec 5, 2020 | 04:30 PM
joe40x's Avatar
joe40x
From the Pingel web site.
These tank fitting kits convert models equipped with fuel injection systems to a carburetor system. The introduction of larger bore engines has surpassed the stock fuel injections ability to deliver adequate fuel. Tank fittings replace the stock fittings allowing the use of a quality Pingel Fuel Valve to feed the carburetor of your choice. Once installed, any Pingel 22mm valve canbe used. Machined from billet stainless steel.
Hoginedgewood
Carburetor Related
Dec 26, 2022 08:13 PM
Chopper Nate
Carburetor Related
Sep 10, 2019 09:17 AM
Scudda
Exhaust System Topics
Mar 9, 2012 09:32 PM
Jaystn62
Oct 28, 2011 01:56 PM
socalsilversxt
Jul 8, 2011 01:17 PM
