Brake light switch
The brake light switch that the motorcycle had came on, the circuit is on and the light turn on when I pressed the brake.
The new handlebar control, the switch works in inverse position and the circuit turn off someone knows how I can solve it, that the switch turns on when I press and that it turns off when I release it
Thanks
When the switch is mounted in the controls, the brake lever will allow the button to extend when the lever is pulled in.
however, if these controls are used and the source is unknown: the switch should be a normally closed switch so if you remove the lever pin so the switch is in its natural state and ohm the wires, it should show continuity, if not, the switch is a normally open switch that some one installed.
Good Luck!!
