1.7 ratio
Old Mar 30, 2021 | 07:17 PM
Richard Bruce's Avatar
Richard Bruce
Default 1.7 ratio
Have a 2016 FLSTFBS with the HD 117 Kit. Stock heads TTS150 Cams. Going to pull the heads and try to obtain more power! I have the stock cams 255, 259E and the currently installed TTS 150. If I install these 1.7 Ratio would that really produce the power vs just getting another cam. Current Comp is 10.1 Was going to zero deck and send off the 110 heads to get massaged . What would you all suggest or do? I'm no pro and this is a question and need help. Thanks
Old Mar 31, 2021 | 02:05 PM
SteveThePirate's Avatar
SteveThePirate
I have no knowledge of the specifics, but generally higher compression = higher horsepower. Tighter squish equals higher compression.
InthewindMN
Engine Mechanical Topics
13
Nov 10, 2016 10:55 AM
txphatboy
Oct 27, 2014 03:43 PM
bernietg
Feb 20, 2013 10:24 PM
Tfrosst
Exhaust System Topics
Nov 4, 2007 08:50 PM
olgreydog7
Jul 16, 2007 12:28 AM
