PJ-1 Equivalent
Old Apr 29, 2021 | 09:30 AM
Fastfwd's Avatar
Fastfwd
Default PJ-1 Equivalent
I'm doing a SE compensator swap and the instructions specify using a 'PJ-1 or Equivalent' to clean the inside of the primary cover. The 'Oil Rib Installation Kit' for the oil deflector that has to be glued inside the primary needs a clean surface to stick to. I already hit it with brake cleaner and some Gunk degreaser.
None of my local PJ-1 dealers have the product that I'm guessing is the one they are suggesting. The 'Super Cleaner.' They have contact cleaner, etc.
What would be the 'equivalent' to the PJ-1 'Super Cleaner'? I'm guessing it is important to not leave behind the residue that Gunk may leave behind that the alcohol cleaning step might not be able to get off.
I just don't want this oil rib thing coming off inside my primary and causing me any issue down the road.
Thanks!
Old Apr 29, 2021 | 11:59 AM
Fastfwd's Avatar
Fastfwd
Found the PJ-1 Super Cleaner
Old Apr 29, 2021 | 01:12 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Maybe help the next guy by posting where you found it?
Old Apr 29, 2021 | 03:00 PM
Fastfwd's Avatar
Fastfwd
The website for PJ-1 lists your local dealers. I called 2. I didn't notice there were 3 locally and that 3rd one had it in stock.
Thanks anyway!
Old Apr 29, 2021 | 08:45 PM
Max Headflow's Avatar
Max Headflow
Any brake cleaner will work. I prefer starting with mineral spirits and ending with denatured alcohol.. Lacquer thinner would probably work also. Use a small brush to work the solvents in and dry with compressed air.
Old Apr 29, 2021 | 10:24 PM
monkeyboy22's Avatar
monkeyboy22
Originally Posted by Fastfwd
... instructions specify using a 'PJ-1 or Equivalent' ...
Thanks!
Any brake cleaner will work....
All of our techs call PJ-1 brake cleaner and when we haven't been able to get it, we use brake cleaner as a substitute.
Old Apr 29, 2021 | 10:58 PM
Max Headflow
PJ1 is a brand name. They make a ton of stuff, paint, fork oil, chain lube, gear oil, various cleaners.
LQQK_OUT
Oil Archive (no new posts)
Oct 8, 2019 02:07 PM
Gary1
Milwaukee Eight (M8)
Sep 23, 2019 01:19 PM
CHARLEY58
Jun 27, 2017 02:54 PM
shorty07ultra
Jul 29, 2014 05:51 PM
jayhawkclint
Jan 7, 2014 01:52 PM
