General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
I am rehabbing a wrecked 05 Road King Classic. The bottom yoke on the triple tree was crunched. Top yoke looks OK. I located a used part on Ebay (dealership was $580!) and it is on the way. My question is: after removing the fork tubes and removing the 1 1/2" nut on the top of the triple tree do you just pound the shaft out? I hate to go whacking on something unless I know it is supposed to give way. Also, I am thinking about taking the fork tubes to a machine shop and see if they can straighten them. Have any of you ever done this? I have a Clymer manual on the way but it's not here yet so I have questions. I am definitely in the broken eggs section of making an omelet. Thanks in advance. Bill
Once I removed cover over the triple tree I saw an unusual nut threaded on the steering shaft. It was only on finger tight. Removed that nut and the triple tree fell right out. Should that nut/keeper only be finger tight? I assume it's to keep the correct amount of torque on the steering bearings.
Yeah it could be.. It sets preload on the steering bearings but requires that the top nut be tight first. Don''t forget to replace the steering bearings and races. You might was to assemble the tubes into the new bottom and top trees and verify that the tubes are parallel.
+1
the fsm should have the fall away spec. pay particular attention to it as steering issues could arise, especially if it is a wreck. although tapered bearing are nice, i still prefer the ole single ball race setup as once adjusted, stays. i have to set my sport every now and then. the older machines had an option for friction control, not any more, all they have now is a add on dampener.
....... Also, I am thinking about taking the fork tubes to a machine shop and see if they can straighten them. Have any of you ever done this?
Stanchions can be straightened, if it's a very slight bend. But given that stanchions aren't particularly expensive, you may be as well off buying a new pair as getting the old ones straightened.
