Helmet dryer
But in the meantime..........nvr saw anything like that.
NICE idea. Being in S. Florida, I sweat and soak the inside a lot. I just bring the helmet inside the house and it dries right out.
Why else would it be wet? Hanging it on the bike upside down and it rains?
Washing it......u take the insides out.
Tho it is a GOOD idea, the boot dryer. I like the ingenuity.
I happened to walk in the room with my boot dryer and said hmmmm this may work.
Likely or clearly not so much in any of the more northern type locations.
Gd point.
Hey OP, drying a helmet liner is great thing, your dryer is awesome.
Me?
I don't use a dryer, yet I will take a dry rag and wipe the inside to "soak up" some sweat if need be.
And ever so often I will take some foaming carpet cleaner and clean the liner.
Lastly when storing, I have taken some crumpled newspaper and placed in the helmet, may help absorb residue moisture & odors.
Well then, the replies have been a bit meager I would say.
Wait a moment. I have to look up the word meager. I nvr used that word before.
I would say, take a wet lid, pop it into a preheated oven at 350 deg for 45 minutes. If the lid is a Large or X-Tra large then 375 deg. for 1H 10 minutes.
Take out and put on cooking rack.
After 30 minutes, sniff the inside of the lid. If it smells dank, put it back into the oven for 15 minutes.
If it smells toasty warm, you are good to go.
Bonus: Put a few drops of vanilla essential oils in the lid to add that extra ahhhh when you will have a bitch behind you to gaurranty getting lad.
FAQ's:
Q: What if you have a SENA?
A: No worries. They are made to tolerate high heat.
Q: What if you have a Go Pro.
A: If you have a Go Pro, just cover it with a standard Zip Lock bag and tighten the zippy part closed the best you can. That should work perfectly. There is no reason to take a Go Pro off at 375 deg's. Don't be a sissy.
Q: How about stickers 'n stuff.
A: ALL stickers are heat resistant unless it is a pink sticker (excluding the ta-ta's) or if the sticker has a faggish saying. Oh wait, I can't say faggish. Ummmm
Q: Will the helmet shrink or warp?
A: No, if it is a good quality DOT'd lid. Any of those fibber pieces of sh*t or a thin fake lid which is worthless to wear and you aren't fooling anyone, yes, those can warp but they will not shrink. If you put the lid back on and it feels tighter than usual, that is simply bcs you found a brilliant way to dry our lid and your head is swelling with ego.
Any additional questions can be submitted to HDF in triplicate. Keep 1 copy for yourself, 1 you can wipe your butt with and send one to us. (Not the one you wiped yourself with.)
Disclaimer: None of the above is true. Though all of it is 100% factual and tested by independent laboratories in Wuhan, they are certified by the CIA, FBI, and Sesame Street to be authentic and correct. Providing you are reading this after snorting coke or if you are crazy 'nuff to have someone like juannieL as a good friend. (juannieL pays people $50 a month to be his friend bcs, well,
The above was provided by the Elite Services Committee of HDF as an unOFFICIAL educational assistance to HDFers.
@Juan L
