Started in gear!!
Old Aug 30, 2021 | 11:08 AM
Swsebek's Avatar
Swsebek
Stage I
Default Started in gear!!
I have a 2006 road king…
I almost always put the king in neutral when I shut it off. But last week I must have forgot when I stopped to fuel up. After fueling I put kick stand up, turned on ignition and pressed starter button without clutch being pulled and it lunged forward a couple strokes. It was almost and embarrassing moment of dropping it. I did it a second time to make sure it was not just a fluke. I did not have clutch pulled in.
Is this normal??
Old Aug 30, 2021 | 11:22 AM
dawg's Avatar
dawg
I know the newer models (starting in 07 I believe) have clutch safety switches so you can’t do that.
Old Aug 30, 2021 | 12:00 PM
Hoginedgewood's Avatar
Hoginedgewood
My 06 would start in gear. 100,000 miles and I didn’t die from it. Just go live your life and ride as much as you want.
Old Aug 30, 2021 | 12:02 PM
MURPHCC1's Avatar
MURPHCC1
no not normal........neutral safety switch must be bad.......
https://partsfinder.onlinemicrofiche...0KING%AE%20(FD)
Old Aug 30, 2021 | 12:12 PM
TwiZted Biker's Avatar
TwiZted Biker
Bad riding habits, never rely on tech for something that should be muscle memory already.
Old Aug 30, 2021 | 12:23 PM
Rob Harper's Avatar
Rob Harper
my '01 will start in gear with clutch out, my '14 you have to have clutch in, or be in N.
Old Aug 30, 2021 | 12:48 PM
DinoM's Avatar
DinoM
Every Harley I've owned up til my current 2017 Road Glide Ultra would start in gear!!! Not sure what year HD implemented the safety switch but even now, I never start my bike without the clutch in and the bike in neutral. I don't like starting it, even KNOWING its in neutral, without pulling the clutch in first.
Old Aug 30, 2021 | 01:03 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Normal...
All `06 and earlier Harley Davidsons will start in gear.
The neutral safety system came out for 2007 models.
Old Aug 30, 2021 | 01:41 PM
monkeyboy22's Avatar
monkeyboy22
What you pointed out is a neutral indicator switch not a safety switch. The safety switch was implemented in '07.
Old Aug 30, 2021 | 02:10 PM
MURPHCC1's Avatar
MURPHCC1
my bad.........got it!!
