Rinehart Header
Old Jan 23, 2022 | 10:25 AM
jb071599's Avatar
jb071599
Default Rinehart Header
I am in the middle of installing a Rinehart Header on my '19 Tri Glide Ultra. The part # is 100-0452, the #'s were confirmed from Rinehart and Direct Cycle Parts. The header is installed, losely as I was about to start making connections after the header. The problem is that the pipe, from cylinder #1 is about 1 inch from the rear frame. There is absolutely nothing that can be connected to the header pipe. The #2 cylinder is fine with the crossover pipes etc. So that is the issue I am having and want to see if any else has had had similar problem.
Thanks
Old Jan 23, 2022 | 09:32 PM
pgreer's Avatar
pgreer
That pipe does not fit a Tri Glide. From what I can find, it's for two wheel model M8 touring bikes. So that is likely why things do not align up.
And, if I recall correctly, the Tri-Glides use the same size muffler connection on both sides. Where the 2 wheel M8 Touring bikes use a larger inlet on the right side muffler.
Paul
bigpappa160
Sep 8, 2018 08:48 AM
Astro
Jul 12, 2012 04:54 PM
NiteOwl
Jan 30, 2011 09:31 AM
george liles
Dec 21, 2007 06:01 PM
ckamin
Exhaust System Topics
Jun 4, 2005 12:38 AM
