General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Your 2022 does not have an in line fuse. It is part of the harness . Fuse is in the Fuse box. On 2020 it is fuse number 4.
The plug you has in the new normal you old charger will work just fine.
OP put the tender on so its not OEM. Read post #1
