Battery tender issues 22 Street Glide
Old Feb 18, 2022 | 12:04 PM
SG2022's Avatar
SG2022
Stage II
Default Battery tender issues 22 Street Glide
Just bought a 22 Street Glide. Put a battery tender on and even after a few hours can’t get a green light. The tender I’m using is a normal 2 terminal tender but the bike has the 3 terminal pigtail. Do I need a Harley tender for the 3 terminals or what’s going on? Any advice would be great. Dealership wasn’t much help. Thanks
Old Feb 18, 2022 | 12:17 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Should not be an issue, what is the tender light doing? If it solid red, it is still charging, if it is blinking red then it is not charging and the fuse in the fuse panel may need to be replaced.
Ignore the third connection, your tender will work just fine.
May take more than a few hours to bring the battery up to the float level.
Old Feb 18, 2022 | 12:31 PM
SG2022's Avatar
SG2022
Stage II
Tender stays solid red. I’ll try it again when I get home. I appreciate it. I’ll let you know. Thank you
Old Feb 18, 2022 | 01:51 PM
CoolBreeze3646
Battery is probably down quite a bit from sitting around at the dealers, give it 24 hours as most tenders only charge at 1.5 volts DC.
Old Feb 18, 2022 | 02:04 PM
RANGER73's Avatar
RANGER73
Check the inline fuse.
The 3rd prong is for a rapid charge connector that you must not have on your tender
Old Feb 19, 2022 | 06:54 AM
jwt873's Avatar
jwt873
My dealer threw in a 'free' 750mA Harley-Davidson Supersmart battery tender with the purchase of my 2022 Road King.
Just for info, the Harley charger doesn't have the third connection.. Only has the regular 2 pin SAE connector.
Old Feb 19, 2022 | 06:45 PM
Max Headflow's Avatar
Max Headflow
I think you mean 1.5 amps? Actually many are below that..
If the Tender is very low amp type it may not be able to charge the battery completely..
Old Feb 19, 2022 | 06:50 PM
CoolBreeze3646
Yeah my bad, 1.5 amps, I think mine does .750 amps. Good catch - Thanks.
Old Feb 20, 2022 | 11:03 PM
profmlb's Avatar
profmlb
Yep, your third wire is for high amp fast charge situations. 5 amp chargers can heat up only one hot wire. Your battery has only two posts.
After my '22 purchase I found that the tender that I am using <1 amp took almost a couple of days before stating full charge, after that I get a full charge in just a few minutes after a long ride.
Old Feb 21, 2022 | 06:06 AM
maxxym's Avatar
maxxym
Solid red means that the battery is charging. It will take some time if the bike sat for a while. Should turn solid green once it is charged.
