How much oil do you go through?
Old May 19, 2022 | 08:38 PM
  #31
Max Headflow's Avatar
Max Headflow
About 10 to 15 quarts a year.
Old May 20, 2022 | 05:58 AM
  #32
slw210's Avatar
slw210
M8 and Sportster no noticeable oil usage between changes.
Old May 20, 2022 | 09:27 AM
  #33
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by gonemad
I wonder what it is about an M8 that causes "so much" oil consumption as compared to, say, a Twin Cam?
Where are you coming up with this?
Do you think that a few responses on a forum tells us that M8`s use more oil than TC`s?
Junk Science.
Old May 20, 2022 | 01:23 PM
  #34
gonemad's Avatar
gonemad
This forum.
…and the moco says up to a quart every 1500 is within spec. Hell, a dealer service dept told me a quart every thousand. Everyone in this thread is adding oil between changes on M-8s. Twin Cam owners not reporting oil usage between. Or if they are they ain’t saying.
This thread is not the first time it’s been discussed.
Seems like a fair question to me.
Old May 20, 2022 | 02:40 PM
  #35
Max Headflow
My TCs burn more oil than my 17 rk... Example. My 07 EGC burns about 1 qt in 4000 to 4500 miles. My RK is about 1/2 that..
Old May 20, 2022 | 03:02 PM
  #36
sonny4's Avatar
sonny4
Twin cams if running right do not burn oil. Change oil full synthetic Mobil bike oil every 5,000 miles no issues. Started to get issues after 120,000 hard miles and now rebuilding.
Old May 20, 2022 | 06:18 PM
  #37
superlow16's Avatar
superlow16
Ok I just check my Sportster and it's still well within the limits of were it should be. It isn't exactly where it was but it isn't anything to freak out about. Considering the amount of riding I've been doing lately in the desert sun I'm happy.
Old May 20, 2022 | 06:27 PM
  #38
superlow16's Avatar
superlow16
I'm sure you guys know these bikes are easy to overfill so freaking out checking it all the time isn't the greatest plan either. I don't know about your bike but if you don't check mine hot you're going to overfill it.
Old May 20, 2022 | 07:35 PM
  #39
Timberwolf2017's Avatar
Timberwolf2017
My 2021 RGL does not use a drop. I change every 4K
Old May 20, 2022 | 08:40 PM
  #40
Max Headflow
I'd be worried about bikes with motors that don't burn a drop of oil. It means that no oil is sticking to the cylinder cross hatch to lubricate the rings and no oil is making past the valve seals to lubricate the guides. Get back to us after you have 40K to 50K
