08 ultra classic intermittently shuts down while riding
General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Welcome from Spartan Country, Michigan! I tell a lot of new comers to the forum to get: Factory Service manual and the Parts manual. Get a three ring binder and record all your maintenance, repairs, accessories, etc. This will be a great reminder of what was done when. And great material to pass along to the new owner should you sell and upgrade. Also know how large your fuel tank is, a rough idea of your range per tank, and record your fuel usage. I have an app called Simply Auto that I record all my fuel used. I use the odometer and use the fuel gage as reference only. I reset the odometer to zero on fill ups, and I know I can safely get 200 miles on a tank on around town riding, and upwards of 230+ on trips. Good Luck!!
On an 08 UC, all the power goes through the ignition switch. If you are losing everything, it is likely your issue. Check all the wires going from the battery to the switch including the maxi fuse. Battery cables, as recommended, also.
This! My 08 had the same issue. The contacts in the rear of the switch can get hot and cause issues.
