General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Can't speak to your windshield, but I use Zeiss lens wipes (saturated in alcohol) on my plastic eyeglass lenses with no issue.
Your glasses have coatings on them. The windshield doesnt. I use Original Bike Spirits (old Honda spray wax and polish formula), or 10% vinegar water.
I originally used Novus products but they are pricy.
The reason I'm asking is that I'm planning on doing a little pin stripping and I need to clean the surface without leaving a film which alcohol does
use a chemical prep
wash with a good wash like Reset by CarPro....rinse in distilled water....dry with a microfiber...spray it down liberally with a paint or polish prep....Gyeon Prep is perfect and will remove any oils, fingerprints, residues, etc
a prep is what a detailer would do as a step prior to sealing, coating, or waxing....is the final remove all possible stuff step
