General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
To all of us who live in northern climates, unfortunately the time of year where we put our rides into hibernation.
I’d like some feedback.
my bike will be kept in my heated garage, on a battery tender, on thick rubber mats, and fuel stabilizer in the tank. I’ll also be changing the oils before storage. Anything else you guys suggest ? Mines carbureted, are there special instructions for that ?
Also, I plan on firing her up a couple of times a week.
When I lived up North, I would turn the petcock off and run carb dry. Stable in tank, park on some carpet squares, and put some smelly dryer sheets on/in bike to keep mice away. Put a tender on the battery and throw a breathable cover over it. Did this for 17 years without a lick of issues and the bike always started right up. My “heated” garage was kept at about 45 degrees. Worked for me......
please explain “turn the petcock off and run the carb dry”
Most important thing is to use non-ethanol fuel. Is that available to you? I put steel wool in my exhaust too. I don't leave the tender on. I put it on once a month, until it floats for a day.
