Space heaters in garages
Old Jan 1, 2023 | 05:06 PM
Steelie68's Avatar
Steelie68
Default Space heaters in garages
I live in a suburb of Buffalo, NY. Blizzard last week and 50's 5 days after. Does anyone reccomend using an electric space heater in garage to keep Temps above freezing for bike storage? I have a 2 1/2 car garage with a drop ceiling and walls are insulated. An electric space heater has to be better than $450 to store at the dealer, right? If you know of a brand or certain one, suggestions appreciated. Thanks!
Popular Reply
Jan 1, 2023, 06:30 PM
chopper_man's Avatar
chopper_man
Why do you have to heat your bike? Makes zero difference. Throw it on a tender and ride it when it's warm, rinse and repeat.
Old Jan 1, 2023 | 05:46 PM
son of the hounds's Avatar
son of the hounds
I live in Idaho. It stayed around 15F-25F for several weeks and we’ve had well over 4’ of snow. The difference here, we get 3”-6” every 12 hours when we have snow. Clear and cold in between.
We have a two car garage, insulated by 1990’s standards. I use two oil filled heaters at 1/2 power setting(750 watt) and half dial heat setting. Only other factor is our water heater is in an alcove connected to the garage.
My wife leaves and returns about once a day. Rapid air cooling, but does not cool the structure so it warms back quickly after the double garage door closes. My garage stays at 40F. Warm enough to work in. Temps rise to about 50F when air temp outside rises to 32F+.
I have milk house heaters, propane heaters, kerosene heaters, but prefer the slow constant temperature controlled oil filled heaters. My bike is on a carpet runner that I got from Home Depot. It is covered loosely with an old bedroom queen size sheet to keep dust off yet allow it to breath.
Oil filled heaters are low and slow. Designed to be on. The other advantage to me is when I come in the side door, my gloves and wool cap get thrown on one heater and if my shoes/boots are wet, the sit on top of the other one. Next time I go out to shovel, gloves are warm, boots are dry and warm.
Im not saying this is the best solution, but it is mine. This is the same system and units I used in my older home, only partially insulated garage. I had the milk house heaters(2) if I needed extra heat while working on projects. Haven’t needed them in this circa 1990’s garage. Bikes, tractor with plow and snow blower take up my half, wife’s car the other.
In the big blows, when power goes, I use my wilderness tent kerosene heater.
If I tried something different, I’d try the mica heater. But my oil heaters are likely to be working long after I’m gone.
Old Jan 1, 2023 | 06:30 PM
chopper_man
Old Jan 2, 2023 | 01:04 AM
hvacgaspiping's Avatar
hvacgaspiping
Batteries don`t like extreme cold and will age quickly even with a trickle charge applied. Also, he said something about a hot water heater in an alcove connected to the garage.... Don`t know if that would be affected by the cold, unless there was no heat around its connected piping.
Old Jan 2, 2023 | 02:37 AM
NorthWestern's Avatar
NorthWestern
Do you have 240v in your garage? You could add easily enough, and go with one of these:
https://www.northerntool.com/shop/to...1888_200631888
I have a 3 1/2 car garage, and actually have a gas furnace out there to heat it.
I have always had heated garages, the investment is worth it, not just for the bike.
Old Jan 2, 2023 | 05:31 AM
MCRD'71's Avatar
MCRD'71
Default Heater
I have this heater for 700 sq ft. I don't like the cold in SE SC.
Old Jan 2, 2023 | 05:54 AM
Steve Sportster's Avatar
Steve Sportster
I keep two cars and my Heritage in my 2.5 car garage. It stays fairly warm in winter due to waste heat from the house. All the walls have insulation. 10-ft + ceiling. Two walls are interior. Garage doors leak and have no real insulation. During the recent cold snap (got to -5 with severe wind chill) the garage temp got to 30F with interior house at 71F. No reason to heat it all the time. When I want to work or play (have a golf simulator) in the garage I use a propane heater like the one shown below. Have used it for about 5 years and no CO issues.
Mr. Heater 30000-BTU Portable Outdoor Propane Tank Top Propane Heater in the Propane Heaters department at Lowes.com
Old Jan 2, 2023 | 06:15 AM
M Oclaf's Avatar
M Oclaf
spending upwards of a thousand dollars or more to keep a couple hundred dollar battery from going bad which it will anyway? Okay!
Old Jan 2, 2023 | 06:58 AM
Riffraff123's Avatar
Riffraff123
I put a good cover on mine and add a 60 watt old school light bulb under it. Keeps condensation down and gives enough warmth that I'm not getting a new battery every other year. I've gotta plan for what to do when old bulbs go instinct.
Old Jan 2, 2023 | 07:08 AM
Steelie68's Avatar
Steelie68
I will not take out bike if it even gets in to the 60's. The roads are usually white, covered in salt. Made that mistake once. Haha. Very difficult to wash. It's an entire production lol... bikes sweat alot with temp fluctuations. Once it's put to sleep, it stays that way until April or May. Sad, but that's what we do up here.
