Do I need a cooler?
Old Feb 14, 2023 | 08:16 PM
Max Headflow's Avatar
Max Headflow
Yeah, You need one.. Need to mount a rack on the back of the bike.. The cooler should hold a 6 pack or more..
Old Feb 15, 2023 | 10:50 PM
OakMountainRider's Avatar
OakMountainRider
Ok, thanks for the advice, Max. I will meet the machine shop guy today and get the cylinders and the pistons. He has bored them from 88 ci to 98 ci, using a Harley stress plate. The heads are at another machine shop here in Stockholm to get compression release valves. Then upon putting the bike together, I will probably install an oil cooler. I have been considering Jaggs Oil Cooler which has a fan in it. Could be useful when getting stuck in the traffic. Also been thinking about the Love Jugs or Mighty Mite fans. Can they be an option in my case, you think, or is an oil cooler preferable?
Old Feb 17, 2023 | 10:35 PM
Clammy's Avatar
Clammy
Originally Posted by cycleman11
My view is that any air cooled bike can benefit from an external oil cooler with a thermostat. On my bone stock 2008 Heritage Softail it lowered the oil temp from 270 F to 250 F under the same high heat conditions. That may not sound like much but it is a significant reduction. On my old 98 Electra Glide, I managed to find a brand new old stock HD factory oil cooler for a good price, so I installed it this winter.
The climate I live in is similar to yours and it is my opinion that you should install one, just make sure it has a thermostat. That way the oil temps won't get too low when its cold. You've gone to all that work and your engine will thank you.
I share this opinion. Even though I've never had an oil cooler installed on Reaper, I should have. Especially considering that I ride lots of miles regularly down in the southern USA during summer, where temps are often well over 100 F. One of the main (stupid) reasons I never did, was because I never found one I liked the look of installed. Recently, I discovered one that will fit my needs and wants: the Oilbud They've been around for years, but somehow, I never heard of them. The cooler is installed under the engine, so except for a couple of oil lines, it's hidden. Everything I've read about the product is positive, so, I'm gonna take the chance, and drop the big bucks (about $700.00) to give it a try.
Cheers!
Old Feb 17, 2023 | 11:14 PM
Max Headflow
The highest temps I've seen on my 2000 FXDX was about 235F, 90 degree days and no traffic but could be running the bike hard, out of the open road. It was a high compression (11.3 to 1) 116. Never really had any heat issues but did run synthetic and no cooler.
Old Feb 18, 2023 | 05:45 AM
60Gunner's Avatar
60Gunner
I built my 103. It is now a 107 with 590 cams, 5.3 injectors, a 30 tooth solid primary sprocket keeping my rpms higher, blah blah and its doing close to 130hp and torque. I ride it hard every time it's out. I have no oil cooler and my oil temps rarely see 240°F even on a 95° day.
I do have a 3 stage oil pump and cam plate. This helps more than an oil cooler by it's scavenging abilities and keeping the oil circulating and not sitting in the engine getting hotter imo.
So does not lugging your engine.
Old Feb 18, 2023 | 05:55 AM
OakMountainRider
I upgraded the camplate, pump and lifters last year, and I agree with you. Oil pressure is good now and signs of sumping are gone. It made a great difference.
Old Feb 18, 2023 | 02:25 PM
Clammy's Avatar
Clammy
Last summer, I was cruising the highway, in Texas, at around 75 mph. It was around 100 - 110 F. When I would come to a mild upgrade in the roadway, I had to drop a gear (even 2 a few times) or the engine would ping like crazy. I do have a Baker DD6 gearset, but except for those crazy hot days, I never have to downshift to simply climb a mild upgrade in the highway. On some steep grades in the mountains, I would have to drop at least to 5th, but I wasn't in the mountains when that was occurring. I don't know what the actual oil temperature was, but it was high, for sure. I always run full synthetic oils, and at the time, and have the S&S cam TC3 oil pump (and cam plate). Reaper's engine was 98 ci @ 10.5:1. That was not the first time I've experienced pinging from high ambient temps. I'm hoping the cooler will solve that, or at least minimize it. We'll see this summer.
Cheers!
Old Feb 19, 2023 | 11:28 AM
60Gunner's Avatar
60Gunner
Cheers!
​​​​​​​A good tune makes a huge difference as well. "Good tune" is a relative term.
An oil cooler will help to some degree with oil temps.
Old Feb 19, 2023 | 12:26 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Cheers!
I don`t think adding an oil cooler will have any effect on the detonation issue.
Detonation is caused by high engine temperatures, usually lean mixture or improper ignition timing.
Old Feb 19, 2023 | 01:40 PM
Clammy's Avatar
Clammy
The tune was dialed in. It was strictly due to the high ambient temps. Under 100 F, there were no pinging issues, whatsoever. Even up to almost 110 it wasn't that bad. Once it hit 110 and above, I experienced the problem big time. The way I see it, lowering the oil temps will lower the engine temps, and that should help to mitigate the problem. Will it cure it, altogether? I won't know until this summer.
Cheers!
