Milwaukee 8 Engine Problems
Of course they all are familiar with these less strong points ,...and they honestly talk it over with me .( just like friends do
I've ordered today a low budget ( from Aliexpress ) endoscope , so that I can check possible carbon build up myself , just before the HD maintenance visits.
Let me make myself clear that I wish you all the very best - , reliable - and flawless M8 motorcycles ,....and no troubles for now and in the future
( and if you should keep it stock , or no further upgrade than Stage 1 ,....and ride the bike nice and gently ,....is that what probably will happen )
One theory was this even started with 103" and getting hotter. I wonder if 96/6 speed and mounting starter directly to primary, which in the past added a small amount of venting.
One interesting thing is the change in fluid levels in 6 speed trannys and primarys. Did they know something was going on?
Never had a primary vent.
Replacing oil pump, on new machine is BS, especically if you have to pay for it.
You didnt say ANYTHING!
Get one and don't look back. Just add gas and go.
From 2020 on, the stock oil pump is perfectly fine for anything you want to do, cam only, big bore, or just stock. I have zero issue with someone wanting to use aftermarket. S&S and fueling make good stuff, but to say that the someone looking at getting new bike needs to also upgrade the oil pump is just ignorant and foolish, and should not be listened to. Also, Fattyonafatboy, since you're looking at getting a Fatboy... sumping has never been an issue with softails due to a different case design for the dual counterbalancers. Get one. I'm confident you won't be disappointed.
Who is putting new oil pumps in new bikes under warranty? Please stop spreading your BS. Go away.
