Milwaukee 8 Engine Problems
Old Sep 8, 2023 | 07:03 AM
  #41
Goose_NC's Avatar
Goose_NC
I have a 2019 FLHTP with 21,000 miles. I bought it with 1120 miles on it in 2021. I had an issue with the tranny fluid migrating to the primary. I installed the Harley vent and have not had that issue since. I frequently ride 150-180 miles at 78 mph on the interstate. Refuel then do it again. I've done several 500+ mile days.
Old Sep 8, 2023 | 07:31 AM
  #42
Rounders's Avatar
Rounders
Originally Posted by sjoko
About the so called "oil transfer issue" : This can be considered as history
This issue only occured in M8 engines which were equipped with the hydraulic clutches.
Due to the shape of the gasket between the trapdoor and the inner side cover , which closes only the outer side of the transmission case , and NOT the space where the rubber cap of the actuator is situated
What happened , was that the actuator also worked like a kind of "balloon pump" by sucking transmission oil through the tiny openings what the gasket did not cover., and press that collected oil through the hollow shaft into the primary , due to these two compartments shared the same closed inner atmosphere.
By making that closed atmosphere leak ( by installing that rubber vent ) , the unwanted "balloon pump" effect had been abolished..
It maybe sounds all a little confusing , but when you ( f.i.) should look up the picture at page 7 - 7 , fig. 4.6b of the Clymer M8 manual , it all will be clear.
Lots of theories on why they had to add a vent after all these years. Another is with the change of starter in 2007, less venting through that. Another, is engines got bigger and hotter, and this probably materializes more on touring bikes, cause they get rode more. I kinda suspect it all adds up. Probably vented a little through starter, than took that away and hydraullic clutch made it worse.
103 TC had hydraullic clutch, no vent, and no venting through starter. Which isn't a lot but some.
I have heard there was some issues before M8. I wouldn't be surprised there was, and most people who change it every 5k don't notice it, if just a little. Fluid levels have changed in the 6 speed tranny before the M8s too. I wonder why.
Old Sep 8, 2023 | 06:23 PM
  #43
sjoko's Avatar
sjoko
The CVO Ultra Glide TC110ci , with hydraulic clutch has a so called "3 piece pushrod" which has the inner diameter of the hollow shaft in the gearbox .
Replacing the stock thin M8 pushrod by such a "3 piece pushrod" was the first solution to prevent oil transfer into the primary
Old Sep 8, 2023 | 07:18 PM
  #44
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Well, it was the first solution attempt....
Old Sep 8, 2023 | 07:26 PM
  #45
tonyd2017's Avatar
tonyd2017
Originally Posted by Fattyonafatboy
Hi everyone, I am well aware that the early M8 engines from 2018 - 2020 had their fair share of mechanical issues. Am in right in thinking that the problems have been ironed out in the 2023 models? I currently have a 2015 twin cam and am think of upgrading to a new fatboy but I keep hearing things like “stick with your twin cam… new M8’s are nothing but trouble…” Are they right? I am interested to hear from anyone that has one and whether they’ve had a good or bad experience with it
yes good
Old Sep 9, 2023 | 10:01 AM
  #46
sjoko's Avatar
sjoko
Yes ,....you're right .....
Old Sep 10, 2023 | 01:56 PM
  #47
60Gunner's Avatar
60Gunner
Originally Posted by NorthWestern
Whatever. Nobody said they did not make a mistake with the prior pumps. I am saying there is now verifiable proof that the latest version is in fact solid.
We can compare the mod list all day, if you want. My 128 with all that and more has 20K miles on the latest version HD oil pump so far, without an issue.
My point was, you should not be telling new guys that are asking for advice that the sky is falling with the latest oil pump version.
Why don't you try telling this to Steve @ Fulsac.
Maybe you shouldn't assume what you know nothing about.
https://www.cvoharley.com/smf/index.php?topic=118283.0
Old Sep 10, 2023 | 02:10 PM
  #48
NorthWestern's Avatar
NorthWestern
YOU HOPELESS, USELESS FU*K
As usual, you are trolling the M8 threads, trying to show your superior intellect as a mechanic. Stop. You can't even review threads correctly, and put dates together.
That post CLEARLY dates the previous version(s) of the pump, and not the newest 8 lobe introduced in the May 26, 2019.
You are bouncing around this site trying to be all-knowing for some reason, and you are nothing but a piece of ****.
Old Sep 10, 2023 | 02:35 PM
  #49
MTBIG G's Avatar
MTBIG G
Another totally useless post.
Good job
Old Sep 10, 2023 | 02:46 PM
  #50
Dan89FLSTC's Avatar
Dan89FLSTC
Now THAT is funny...
Fake internet mechanic.
